Bilis518
(Bilis518)
1
I have pass all this afternoon to try to concatenate strings…
Tried Join, +, & with no luck!
Do you know the synthax?
Thanks a lot for your help.
- device_id: 04f3b98e4924c358996481802d04641d
domain: mobile_app
type: notify
title: ''
message: '{{ ''mobile_'' & trigger.entity_id.split(''.'')[1] }}'
AllHailJ
(J Gent)
2
I believe it is a ~ like this
message: '{{ ''mobile_'' ~ trigger.entity_id.split(''.'')[1] }}'
Bilis518
(Bilis518)
3
Many thanks, it works great now!
rccoleman
(Rob Coleman)
4
The part after the “.” is called the object_id, so you could also access it with trigger.to_state.object_id.
+ can be used to operate on like objects, and I would have expected {{ 'mobile_' + trigger.to_state.object_id }} to work. This works for me:
{{ "foo_" + states.switch.fr_table_lamp.object_id }} → foo_fr_table_lamp
~ can concatenate arguments of different types. For instance,
{{ "foo" + 5 }} results in
TypeError: can only concatenate str (not "int") to str
But {{ "foo" ~ 5 }} produces the likely desired result:
foo5
