Just Updated to 0.21 and now things stopped working
I have HA installed on a Pi2 using the All-In-One Installer. All was working fine until tonight when I upgraded to 0.21. HA still launches and works. I don’t have any automation yet but was working on that tonight too. I can turn things on and off in the front end but I can’t restart or stop using the developers tools. I’m also not getting any logs or history anymore in the front end either. However my home-assistant.log file has lots of errors. I can see the restart request but it’s not restarting.
We can’t help if you don’t tell us about your errors. If there are config validation errors, those have to be resolved first.
Sorry. I didn’t want to just post the log. It’s big. This is what the top of my log file looks like:
16-06-08 23:01:30 netdisco.ssdp: Error fetching description at http://192.168.1.1:8200/rootDesc.xml
16-06-08 23:01:31 netdisco.ssdp: Error fetching description at https://192.168.1.3:8888
16-06-08 23:01:32 pywemo.ssdp: Error fetching description at http://192.168.1.1:8200/rootDesc.xml
16-06-08 23:01:33 pywemo.ssdp: Error fetching description at https://192.168.1.3:8888
16-06-08 23:09:30 homeassistant.core: BusHandler:Exception doing job
  File "/srv/hass/hass_venv/lib/python3.4/site-packages/homeassistant/core.py", line 809, in job_handler
    func(arg)
  File "/srv/hass/hass_venv/lib/python3.4/site-packages/homeassistant/helpers/event.py", line 179, in pattern_time_change_listener
    action(now)
  File "/srv/hass/hass_venv/lib/python3.4/site-packages/homeassistant/helpers/entity_component.py", line 191, in _update_entity_states
    entity.update_ha_state(True)
  File "/srv/hass/hass_venv/lib/python3.4/site-packages/homeassistant/helpers/entity.py", line 145, in update_ha_state
    self.update()
  File "/srv/hass/hass_venv/lib/python3.4/site-packages/homeassistant/components/light/wink.py", line 118, in update
    self.wink.update_state(require_desired_state_fulfilled=True)
  File "/home/hass/deps/pywink/devices/base.py", line 58, in update_state
    response = self.api_interface.get_device_state(self)
  File "/home/hass/deps/pywink/api.py", line 42, in get_device_state
    return arequest.json()
  File "/srv/hass/hass_venv/lib/python3.4/site-packages/requests/models.py", line 812, in json
    return complexjson.loads(self.text, **kwargs)
  File "/usr/lib/python3.4/json/__init__.py", line 318, in loads
    return _default_decoder.decode(s)
  File "/usr/lib/python3.4/json/decoder.py", line 343, in decode
    obj, end = self.raw_decode(s, idx=_w(s, 0).end())
  File "/usr/lib/python3.4/json/decoder.py", line 361, in raw_decode
    raise ValueError(errmsg("Expecting value", s, err.value)) from None
ValueError: Expecting value: line 1 column 1 (char 0)
16-06-08 23:11:34 pynetgear: Error talking to API
  File "/srv/hass/hass_venv/lib/python3.4/site-packages/requests/packages/urllib3/connectionpool.py", line 385, in _make_request
    httplib_response = conn.getresponse(buffering=True)
TypeError: getresponse() got an unexpected keyword argument 'buffering'
  File "/srv/hass/hass_venv/lib/python3.4/site-packages/requests/packages/urllib3/connectionpool.py", line 387, in _make_request
    httplib_response = conn.getresponse()
  File "/usr/lib/python3.4/http/client.py", line 1172, in getresponse
    response.begin()
  File "/usr/lib/python3.4/http/client.py", line 351, in begin
    version, status, reason = self._read_status()
  File "/usr/lib/python3.4/http/client.py", line 313, in _read_status
    line = str(self.fp.readline(_MAXLINE + 1), "iso-8859-1")
  File "/usr/lib/python3.4/socket.py", line 371, in readinto
    return self._sock.recv_into(b)
socket.timeout: timed out
  File "/srv/hass/hass_venv/lib/python3.4/site-packages/requests/adapters.py", line 403, in send
    timeout=timeout
  File "/srv/hass/hass_venv/lib/python3.4/site-packages/requests/packages/urllib3/connectionpool.py", line 623, in urlopen
    _stacktrace=sys.exc_info()[2])
  File "/srv/hass/hass_venv/lib/python3.4/site-packages/requests/packages/urllib3/util/retry.py", line 255, in increment
    raise six.reraise(type(error), error, _stacktrace)
  File "/srv/hass/hass_venv/lib/python3.4/site-packages/requests/packages/urllib3/packages/six.py", line 310, in reraise
    raise value
  File "/srv/hass/hass_venv/lib/python3.4/site-packages/requests/packages/urllib3/connectionpool.py", line 578, in urlopen
    chunked=chunked)
  File "/srv/hass/hass_venv/lib/python3.4/site-packages/requests/packages/urllib3/connectionpool.py", line 389, in _make_request
    self._raise_timeout(err=e, url=url, timeout_value=read_timeout)
  File "/srv/hass/hass_venv/lib/python3.4/site-packages/requests/packages/urllib3/connectionpool.py", line 314, in _raise_timeout
    raise ReadTimeoutError(self, url, "Read timed out. (read timeout=%s)" % timeout_value)
requests.packages.urllib3.exceptions.ReadTimeoutError: HTTPConnectionPool(host='routerlogin.net', port=5000): Read timed out. (read timeout=10)
  File "/home/hass/deps/pynetgear/__init__.py", line 113, in _make_request
    self.soap_url, headers=headers, data=message, timeout=10)
  File "/srv/hass/hass_venv/lib/python3.4/site-packages/requests/api.py", line 111, in post
    return request('post', url, data=data, json=json, **kwargs)
  File "/srv/hass/hass_venv/lib/python3.4/site-packages/requests/api.py", line 57, in request
    return session.request(method=method, url=url, **kwargs)
  File "/srv/hass/hass_venv/lib/python3.4/site-packages/requests/sessions.py", line 475, in request
    resp = self.send(prep, **send_kwargs)
  File "/srv/hass/hass_venv/lib/python3.4/site-packages/requests/sessions.py", line 585, in send
    r = adapter.send(request, **kwargs)
  File "/srv/hass/hass_venv/lib/python3.4/site-packages/requests/adapters.py", line 479, in send
    raise ReadTimeout(e, request=request)
requests.exceptions.ReadTimeout: HTTPConnectionPool(host='routerlogin.net', port=5000): Read timed out. (read timeout=10)
yeah, had the same problem, i reinstalled HA using AIO installer. just make sure to backup ur configuration file
yes i am having a issues after i updated to .21…
my camera (dlink) its was working fine…i had two cam… both side by side show only still image .when you click on any cam… its pop up and show real time… after update to .21 … pop up realtime stop working showing idle for # of minutes or hours
