Trying to keep it up to date as possible, and as much documented for other beginners like me.
I hope that everyone will find here somthing that come in handy
I have also incorporated my own theme called Aurora Frost
@yuvalabou how to add this theme to ha?
It’s right there under the theme folder in my git, you can copy the file and call “reload themes” from the UI
OnlyOnlyOnly I can’t find the file and not the folder with that name
In your git repository, hence the question of how to add it, even trying to search by name is ineffective, as you can see below
is it an older version of this or something, because it looks completely different for me Share your Themes - #291 by silvrr
what could be the reason for such differences?
You don’t have the background file and some of the variables have likely changed in the past year. It’s pretty close though other than the sidebar.
do you know how to fix it to make the theme look like in the author’s first post?
There is a list of variables here. [WIP] Supported Theming Variables · home-assistant/frontend Wiki · GitHub
Looks like there may have been some custom cards used though. You can tweak the variables until you get something close.
