As for ssl, are you using DuckDns? If so, you need to port forward 443 external to 8123 internal on your HomeAssistant ip address.
By entities, do you mean known devices?
If I delete known devices and let it repopulate could that help?
Is there anything besides media_player that interferes? If so I will check that, but I have no media players in my known entities.
I used DuckDNS but I set up everything through 8443 instead of 443 to keep 443 open.
I mean entities. This would be seen/filtered from the home assistant side.
Iām not sure what you mean by āknown devicesā . Do you mean the devices on alexaās side?
Not that i know of.
Are you putting the port in everything for the alexa configuration?
Ahh thanks for the clarification. I have two showing up, my samsung tv and my nvidia shield. Can I disable them somehow to see if that fixes it?
Yes, and it works fine from the ātestā code.
Yeah, try that. from what Iāve seen media_players are the only issue at the moment. And itās not all media players with the issue.
Whats the best process to disable them?
Trying to find out what methods to disable media player would work.
I tried disabling from the front end but that didnt do the job.
Disable them through the configuration I posted before with the include/exclude entities.
If that doesnāt work for you check what region your lamba function is in. I had the exact same experience in the Oregon region but when I recreated in the Virginia region everything worked great.
I am oregon. I will try changing to virginiaā¦ is that just a swap or do I have to recreate everything?
There was no move option for me but Iām not a big AWS guy. I had to recreate everything in the new region.
FFFFfffffjuuuuuuu
That totally worked. Switched to Viginia (from Oregon). Copied and pasted everything over. Discovered devices. Boom.
Thank you to BOTH @krinehart & @petro for spending so much time trying to help me out.
Nice! Glad it worked.
So after accidentally discovering 750+ devices due to what I believe was incorrect spacing on my exclude filterā¦ I am nervous to run discover devices againā¦ is there a way to verify what entities are exposed before-hand similar to api/pi/lights or whatever it is for emulated hue?
Good questionā¦ Not sure. Iāll have to dig into that.
So apparently something is still not right with my filterā¦ it just discovered all my devices/entities againā¦ is there something I am doing wrong here?
smart_home:
locale: en-US
endpoint: https://api.amazonalexa.com/v3/events
client_id: ##############
client_secret: #################
filter:
include_entities:
- binary_sensor.multisensor_motion
- binary_sensor.front_door
- binary_sensor.side_door
- binary_sensor.garage_door
exclude_domains:
- alarm_control_panel
- alert
- automation
- binary_sensor
- camera
- climate
- cover
- fan
- group
- input_boolean
- input_number
- image_processing
- light
- lock
- media_player
- scene
- script
- sensor
- switch
- timer
- vacuum
EDIT: Edited to correct indentation to prevent someone from copying the wrong oneā¦
There are actually instructions for a test I must have missed on the pageā¦ but now I am concerned the ātestā may actually discovery devices as I am still unsure what is wrong with my filterā¦
āTest the Lambda functionā
So I was definitely able to test it with the Lambda test function mentioned in the docs, but had to set DEBUG=true in the environment variables or it just gave a 401 errorā¦ so it listed ALL of my devices stillā¦ filter still not working
I had my āalexa:ā config as an !include in my configuration.yamlā¦ moved it directly to my configuration.yaml and now the filter is working!!
That means the configuration was incorrect inside your include. Hereās what I have:
configuration.yaml
alexa: !include alexa.yaml
alexa.yaml
smart_home:
filter:
include_entities:
- fan.bonus_room_bedroom
... etc ...
entity_config:
fan.bonus_room_bedroom:
... etc ...
My guess is that your spacing was off at the smart_home level.
So I needed to indent the whole include probably and didnāt? (I will look at what I had when I get back in the house) I just assumed that because the first few lines were working that the whole thing was correctā¦
