Add ability to set the low latency mode on/off via the remote (see PMLL command).
Use case:
When switching inputs on my AVR between gaming and non-gaming sources I want to switch low latency on (for gaming), or off (for other sources).
Use case:
Can you do it via your remote? Can you not emulates those key presses with the documented remote presses?
