Hi everyone,
I’d like Home assistant to not remember the state of my KAKU AWST-8802 double wall switch.
I switched from domoticz to Home assistant. I use the wall switch to start four different light settings. To clarify:
Button left top: lights 100%
Button left bottom: lights 50%
Button right top: lights OFF
Button right bottom: lights 25%
The switch is not an actual rocker switch and doesn’t have a physical state. But when i press left bottom then the right bottom and when i then want to pres left bottom again it doesn’t react because HA thinks the left rocker is still in that position. I have to press the left top before i can press the left bottom again.
I’m using an event node in Node RED with a switch node and a call service node.
Maybe this is a NOOB question but i searched the forum and am still switching in my head from domoticz to Home assistant and i can’t figure it out. Thanks in advance for any help.
