Kanban for hassio
Hi all , I currently run a Kanban in a docker container on an old server i have which is a bit of overkill does anyone know if there is plugin for hassio ?
If you want to run extra Docker containers on HASSIO install the Portainer add on and then you can launch extra containers. Assuming Kanban has a Docker Conatiner with the correct cpu setup as your HASSIO Host machine.
Or install the ssh & web terminal and just run docker run as you normally woulf.
Thanks I will give it a go
Sorry for the delay just been very busy I installed Kanboad via Portainer and it worked a treat thanks
