I recently installed a HS220 and got it working easily enough after manually adding it to the yaml file. After I added an additional switch to the setup I keep getting unavailable to one or the other or even both.
I even updated to the lastest stable to see if that could fix it and now neither work.
Is there something I need to do now or can I just for the time being set them up as standard switches till the bug is fixex. Thanks.
