Kasa plugs and switches giving errors and warnings
looking for some help on a kasa integration. i’m on home assistant version 2023.3.1
I have a couple plugs and a light switch, and i keep getting random errors and warnings in the logs for each Kasa device. I tried rebooting the entire system (modem, router, and Home Assistant), but it didn’t clear up the issue.
Here is the log:
Logger: homeassistant.config_entries Source: config_entries.py:1244 First occurred: 3:14:41 PM (2 occurrences) Last logged: 3:28:49 PM
Config entry 'Plug - master bedroom HS103(US)' for tplink integration not ready yet: Unable to connect to the device: 192.168.1.80: [Errno 113] Connect call failed ('192.168.1.80', 9999); Retrying in background
Logger: homeassistant.components.tplink.coordinator Source: helpers/update_coordinator.py:182 Integration: TP-Link Kasa Smart (documentation, issues) First occurred: 3:22:10 PM (1 occurrences) Last logged: 3:22:10 PM
Error fetching 192.168.1.101 data: Unable to connect to the device: 192.168.1.101: [Errno 111] Connect call failed ('192.168.1.101', 9999)
I find it weird that the IP address in the first error doesn’t match the second one, even though the “Plug - master bedroom” device IP address is the 192.168.1.101 shown in the second log entry
Looks to me like those devices aren’t connected to the wifi. Can you access them using the KASA app? Can you ping them? Try rebooting those devices, not HA.
I can access them through the Kasa app; however, I am not able to get a ping response from them from my computer’s command line.
I’m assuming the plug can be reset by just removing the plug and reinstalling after a while. Is that right?
