Ive set up Brordlink with Home Assistant this week
All working well except my TV uses the same code for both off and on
I have some Tasmota BlitzWolf SHP smart plugs that measure current wondering if there is a way to use the value of current drawn to keep the status of the entity in sync? So if the value is over a threshold set the value to on without sending the IR code even if the on command hasn’t been called.
Yes, that’s what I do.
I have a single broadlink switch that’s the TVs on/off IR code, then have a template switch that uses the power reading (>40w) to determine the on/off status.
There might be cleaner ways to do it, but this works for me.
