Hi
I keep getting an error and I can’t understand how to fix it
Logger: homeassistant.config
Source: config.py:454
First occurred: 08:51:57 (6 occurrences)
Last logged: 08:51:57
Invalid config for [automation]: Invalid trigger configuration. Got OrderedDict([(‘default_config’, {}), (‘http’, OrderedDict([(‘ssl_certificate’, ‘/ssl/fullchain.pem’), (‘ssl_key’, ‘/ssl/privkey.pem’), (‘login_attempts_threshold’, -1), (‘ssl_profile’, ‘modern’), (‘server_port’, 8123), (‘ip_ban_enabled’, True), (‘cors_allowed_origins’, [‘https://cast.home-assistant.io’])])), (‘api’, {}), (‘alexa’, OrderedDict([(‘smart_home’, None)])), (‘tts’, [OrderedDict([(‘platform’, ‘google_translate’)])]), (‘group’, {}), (‘automation’, [OrderedDict([(‘id’, ‘1632064544043’… (See /config/configuration.yaml, line 16).
What do I do?
