ghstudio
(douglas weiss)
June 30, 2020, 10:07pm
1
I am struggling to get this simple script working. I keep getting an error message:
missed comma between flow collection entries at line 47, column 9:
{% if states('sensor.maverick_tem …
'grate_status':
alias:
sequence:
- service: notify.alexa_media_doug_office
data_template:
{% if states('sensor.maverick_temp1') | float > 0 %}
message: 'grill temperature is {{ states(''sensor.maverick_temp1'')
{% else %}
{% endif %}
target: media_player.doug_office
type: tts
I may have indent errors, but the error message I’m getting is completely confusing…
Ultimately this will be a list of if’s…
Can anyone help…
finity
July 1, 2020, 12:10am
2
That’s because you have the “if” in the wrong place. And you didn’t use the yaml “multi-line” indicator (>). And you have nothing in the “else” section.
Should be:
data_template:
message: >
'grill temperature is {{ states(''sensor.maverick_temp1'') }}'
{% else %}
'Something else here'
{% endif %}
type: tts
123
(Taras)
July 1, 2020, 12:28am
3
Unless you grill in the dead of winter, I’m trying to understand why you even need a test to confirm the grill temperature is greater than zero .
If it’s like my diy smoker sensor it will show 0 if the probe isn’t connected or if there is some other malfunction.
ghstudio
(douglas weiss)
July 1, 2020, 1:23pm
5
Does not work…
error msg:
Invalid config for [script]: invalid template (TemplateSyntaxError: expected token ',', got 'sensor') for dictionary value @ data['script']['grate_status']['sequence'][0]['data_template']['message']. Got "{% if states('sensor.maverick_temp1') | float > 0 %}\n 'grill temperature is {{ states(''sensor.maverick_temp1'') }}'\n{% else %}\n 'Something else here'\n{% endif %}\n".
here is my script code…in case I made an error copying:
'grate_status':
alias: speak maverick
sequence:
data_template:
message: >
{% else %}
{% endif %}
type: tts
try removing all but the essential quotation marks:
grate_status:
sequence:
data_template:
message: >
grill temperature is {{ states('sensor.maverick_temp1') }}
{% else %}
Something else here
{% endif %}
type: tts
