Keep having issues with Zigbee2MQTT addon - keeps becoming unresponsive
Hi there.
I seem to keep having an issue with my particular setup.
I an running HA on a Pi3 and using this particular stick for Zigbee control:
https://electrolama.com/radio-docs/zigbee2mqtt/
I am also using an SSD for my data disk (via a USB to Sata converter).
At the moment, I have three Ikea lights connected via the Zigbee2MQTT add on but, I constantly find that I lost the ability to control the lights via the dashboard - i.e. the on switch, on the dashboard will not stay on. However, I can still successfully change the light’s brightness with quite some delay.
Something is not quite right and I cannot work out what it is.
I tried looking at the addon map and got “Failed to execute LQI for coordinator”.
A restart of the addon usually gets everything going again until I get the same problem.
The log from the add on is showing the following:
Zigbee2MQTT:error 2022-09-22 17:40:32: Publish 'set' 'state' to 'Bedroom' failed: 'Error: Command 0x804b50fffe9fc8f0/1 genOnOff.on({}, {"sendWhen":"immediate","timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (SRSP - AF - dataRequest after 6000ms)'
Zigbee2MQTT:debug 2022-09-22 17:40:32: Error: Command 0x804b50fffe9fc8f0/1 genOnOff.on({}, {"sendWhen":"immediate","timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (SRSP - AF - dataRequest after 6000ms)
    at Timeout._onTimeout (/app/node_modules/zigbee-herdsman/src/utils/waitress.ts:64:35)
    at listOnTimeout (node:internal/timers:559:17)
    at processTimers (node:internal/timers:502:7)
Zigbee2MQTT:info  2022-09-22 17:40:32: MQTT publish: topic 'zigbee2mqtt/bridge/log', payload '{"message":"Publish 'set' 'state' to 'Bedroom' failed: 'Error: Command 0x804b50fffe9fc8f0/1 genOnOff.on({}, {\"sendWhen\":\"immediate\",\"timeout\":10000,\"disableResponse\":false,\"disableRecovery\":false,\"disableDefaultResponse\":false,\"direction\":0,\"srcEndpoint\":null,\"reservedBits\":0,\"manufacturerCode\":null,\"transactionSequenceNumber\":null,\"writeUndiv\":false}) failed (SRSP - AF - dataRequest after 6000ms)'","meta":{"friendly_name":"Bedroom"},"type":"zigbee_publish_error"}'
Zigbee2MQTT:error 2022-09-22 17:40:38: Publish 'set' 'state' to 'Bedroom' failed: 'Error: Command 0x804b50fffe9fc8f0/1 genOnOff.on({}, {"sendWhen":"immediate","timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (SRSP - AF - dataRequest after 6000ms)'
Zigbee2MQTT:debug 2022-09-22 17:40:38: Error: Command 0x804b50fffe9fc8f0/1 genOnOff.on({}, {"sendWhen":"immediate","timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (SRSP - AF - dataRequest after 6000ms)
Zigbee2MQTT:info  2022-09-22 17:40:38: MQTT publish: topic 'zigbee2mqtt/bridge/log', payload '{"message":"Publish 'set' 'state' to 'Bedroom' failed: 'Error: Command 0x804b50fffe9fc8f0/1 genOnOff.on({}, {\"sendWhen\":\"immediate\",\"timeout\":10000,\"disableResponse\":false,\"disableRecovery\":false,\"disableDefaultResponse\":false,\"direction\":0,\"srcEndpoint\":null,\"reservedBits\":0,\"manufacturerCode\":null,\"transactionSequenceNumber\":null,\"writeUndiv\":false}) failed (SRSP - AF - dataRequest after 6000ms)'","meta":{"friendly_name":"Bedroom"},"type":"zigbee_publish_error"}'
Zigbee2MQTT:error 2022-09-22 17:40:44: Publish 'set' 'state' to 'Bedroom' failed: 'Error: Command 0x804b50fffe9fc8f0/1 genOnOff.on({}, {"sendWhen":"immediate","timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (SRSP - AF - dataRequest after 6000ms)'
Zigbee2MQTT:debug 2022-09-22 17:40:44: Error: Command 0x804b50fffe9fc8f0/1 genOnOff.on({}, {"sendWhen":"immediate","timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (SRSP - AF - dataRequest after 6000ms)
Zigbee2MQTT:info  2022-09-22 17:40:44: MQTT publish: topic 'zigbee2mqtt/bridge/log', payload '{"message":"Publish 'set' 'state' to 'Bedroom' failed: 'Error: Command 0x804b50fffe9fc8f0/1 genOnOff.on({}, {\"sendWhen\":\"immediate\",\"timeout\":10000,\"disableResponse\":false,\"disableRecovery\":false,\"disableDefaultResponse\":false,\"direction\":0,\"srcEndpoint\":null,\"reservedBits\":0,\"manufacturerCode\":null,\"transactionSequenceNumber\":null,\"writeUndiv\":false}) failed (SRSP - AF - dataRequest after 6000ms)'","meta":{"friendly_name":"Bedroom"},"type":"zigbee_publish_error"}'
Zigbee2MQTT:error 2022-09-22 17:40:50: Publish 'set' 'state' to 'Bedroom' failed: 'Error: Command 0x804b50fffe9fc8f0/1 genOnOff.on({}, {"sendWhen":"immediate","timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (SRSP - AF - dataRequest after 6000ms)'
Zigbee2MQTT:debug 2022-09-22 17:40:50: Error: Command 0x804b50fffe9fc8f0/1 genOnOff.on({}, {"sendWhen":"immediate","timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (SRSP - AF - dataRequest after 6000ms)
Zigbee2MQTT:info  2022-09-22 17:40:50: MQTT publish: topic 'zigbee2mqtt/bridge/log', payload '{"message":"Publish 'set' 'state' to 'Bedroom' failed: 'Error: Command 0x804b50fffe9fc8f0/1 genOnOff.on({}, {\"sendWhen\":\"immediate\",\"timeout\":10000,\"disableResponse\":false,\"disableRecovery\":false,\"disableDefaultResponse\":false,\"direction\":0,\"srcEndpoint\":null,\"reservedBits\":0,\"manufacturerCode\":null,\"transactionSequenceNumber\":null,\"writeUndiv\":false}) failed (SRSP - AF - dataRequest after 6000ms)'","meta":{"friendly_name":"Bedroom"},"type":"zigbee_publish_error"}'
Zigbee2MQTT:debug 2022-09-22 17:41:05: Saving state to file /config/zigbee2mqtt/state.json
Zigbee2MQTT:debug 2022-09-22 17:46:04: Received MQTT message on 'zigbee2mqtt/Bedroom/set' with data '{"state":"ON"}'
Zigbee2MQTT:debug 2022-09-22 17:46:04: Publishing 'set' 'state' to 'Bedroom'
Zigbee2MQTT:debug 2022-09-22 17:46:05: Saving state to file /config/zigbee2mqtt/state.json
Zigbee2MQTT:error 2022-09-22 17:46:10: Publish 'set' 'state' to 'Bedroom' failed: 'Error: Command 0x804b50fffe9fc8f0/1 genOnOff.on({}, {"sendWhen":"immediate","timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (SRSP - AF - dataRequest after 6000ms)'
Zigbee2MQTT:debug 2022-09-22 17:46:10: Error: Command 0x804b50fffe9fc8f0/1 genOnOff.on({}, {"sendWhen":"immediate","timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (SRSP - AF - dataRequest after 6000ms)
Zigbee2MQTT:info  2022-09-22 17:46:10: MQTT publish: topic 'zigbee2mqtt/bridge/log', payload '{"message":"Publish 'set' 'state' to 'Bedroom' failed: 'Error: Command 0x804b50fffe9fc8f0/1 genOnOff.on({}, {\"sendWhen\":\"immediate\",\"timeout\":10000,\"disableResponse\":false,\"disableRecovery\":false,\"disableDefaultResponse\":false,\"direction\":0,\"srcEndpoint\":null,\"reservedBits\":0,\"manufacturerCode\":null,\"transactionSequenceNumber\":null,\"writeUndiv\":false}) failed (SRSP - AF - dataRequest after 6000ms)'","meta":{"friendly_name":"Bedroom"},"type":"zigbee_publish_error"}'
Zigbee2MQTT:debug 2022-09-22 17:46:19: Received MQTT message on 'zigbee2mqtt/Bedroom/set' with data '{"state":"ON"}'
Zigbee2MQTT:debug 2022-09-22 17:46:19: Publishing 'set' 'state' to 'Bedroom'
Zigbee2MQTT:error 2022-09-22 17:46:25: Publish 'set' 'state' to 'Bedroom' failed: 'Error: Command 0x804b50fffe9fc8f0/1 genOnOff.on({}, {"sendWhen":"immediate","timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (SRSP - AF - dataRequest after 6000ms)'
Zigbee2MQTT:debug 2022-09-22 17:46:25: Error: Command 0x804b50fffe9fc8f0/1 genOnOff.on({}, {"sendWhen":"immediate","timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (SRSP - AF - dataRequest after 6000ms)
Zigbee2MQTT:info  2022-09-22 17:46:25: MQTT publish: topic 'zigbee2mqtt/bridge/log', payload '{"message":"Publish 'set' 'state' to 'Bedroom' failed: 'Error: Command 0x804b50fffe9fc8f0/1 genOnOff.on({}, {\"sendWhen\":\"immediate\",\"timeout\":10000,\"disableResponse\":false,\"disableRecovery\":false,\"disableDefaultResponse\":false,\"direction\":0,\"srcEndpoint\":null,\"reservedBits\":0,\"manufacturerCode\":null,\"transactionSequenceNumber\":null,\"writeUndiv\":false}) failed (SRSP - AF - dataRequest after 6000ms)'","meta":{"friendly_name":"Bedroom"},"type":"zigbee_publish_error"}'
Zigbee2MQTT:debug 2022-09-22 17:46:50: Received MQTT message on 'zigbee2mqtt/Bedroom/set' with data '{"state":"ON"}'
Zigbee2MQTT:debug 2022-09-22 17:46:50: Publishing 'set' 'state' to 'Bedroom'
Zigbee2MQTT:error 2022-09-22 17:46:56: Publish 'set' 'state' to 'Bedroom' failed: 'Error: Command 0x804b50fffe9fc8f0/1 genOnOff.on({}, {"sendWhen":"immediate","timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (SRSP - AF - dataRequest after 6000ms)'
Zigbee2MQTT:debug 2022-09-22 17:46:56: Error: Command 0x804b50fffe9fc8f0/1 genOnOff.on({}, {"sendWhen":"immediate","timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (SRSP - AF - dataRequest after 6000ms)
Zigbee2MQTT:info  2022-09-22 17:46:56: MQTT publish: topic 'zigbee2mqtt/bridge/log', payload '{"message":"Publish 'set' 'state' to 'Bedroom' failed: 'Error: Command 0x804b50fffe9fc8f0/1 genOnOff.on({}, {\"sendWhen\":\"immediate\",\"timeout\":10000,\"disableResponse\":false,\"disableRecovery\":false,\"disableDefaultResponse\":false,\"direction\":0,\"srcEndpoint\":null,\"reservedBits\":0,\"manufacturerCode\":null,\"transactionSequenceNumber\":null,\"writeUndiv\":false}) failed (SRSP - AF - dataRequest after 6000ms)'","meta":{"friendly_name":"Bedroom"},"type":"zigbee_publish_error"}'
Zigbee2MQTT:debug 2022-09-22 17:46:58: Received MQTT message on 'zigbee2mqtt/Bedroom/set' with data '{"state":"ON","brightness":125}'
Zigbee2MQTT:debug 2022-09-22 17:46:58: Publishing 'set' 'brightness' to 'Bedroom'
Zigbee2MQTT:debug 2022-09-22 17:47:01: Received MQTT message on 'zigbee2mqtt/Bedroom/set' with data '{"state":"ON","brightness":3}'
Zigbee2MQTT:debug 2022-09-22 17:47:01: Publishing 'set' 'brightness' to 'Bedroom'
Zigbee2MQTT:error 2022-09-22 17:47:04: Publish 'set' 'brightness' to 'Bedroom' failed: 'Error: Command 0x804b50fffe9fc8f0/1 genLevelCtrl.moveToLevelWithOnOff({"level":125,"transtime":0}, {"sendWhen":"immediate","timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (SRSP - AF - dataRequest after 6000ms)'
Zigbee2MQTT:debug 2022-09-22 17:47:04: Error: Command 0x804b50fffe9fc8f0/1 genLevelCtrl.moveToLevelWithOnOff({"level":125,"transtime":0}, {"sendWhen":"immediate","timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (SRSP - AF - dataRequest after 6000ms)
Zigbee2MQTT:info  2022-09-22 17:47:04: MQTT publish: topic 'zigbee2mqtt/bridge/log', payload '{"message":"Publish 'set' 'brightness' to 'Bedroom' failed: 'Error: Command 0x804b50fffe9fc8f0/1 genLevelCtrl.moveToLevelWithOnOff({\"level\":125,\"transtime\":0}, {\"sendWhen\":\"immediate\",\"timeout\":10000,\"disableResponse\":false,\"disableRecovery\":false,\"disableDefaultResponse\":false,\"direction\":0,\"srcEndpoint\":null,\"reservedBits\":0,\"manufacturerCode\":null,\"transactionSequenceNumber\":null,\"writeUndiv\":false}) failed (SRSP - AF - dataRequest after 6000ms)'","meta":{"friendly_name":"Bedroom"},"type":"zigbee_publish_error"}'
Zigbee2MQTT:error 2022-09-22 17:47:10: Publish 'set' 'brightness' to 'Bedroom' failed: 'Error: Command 0x804b50fffe9fc8f0/1 genLevelCtrl.moveToLevelWithOnOff({"level":3,"transtime":0}, {"sendWhen":"immediate","timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (SRSP - AF - dataRequest after 6000ms)'
Zigbee2MQTT:debug 2022-09-22 17:47:10: Error: Command 0x804b50fffe9fc8f0/1 genLevelCtrl.moveToLevelWithOnOff({"level":3,"transtime":0}, {"sendWhen":"immediate","timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (SRSP - AF - dataRequest after 6000ms)
Zigbee2MQTT:info  2022-09-22 17:47:10: MQTT publish: topic 'zigbee2mqtt/bridge/log', payload '{"message":"Publish 'set' 'brightness' to 'Bedroom' failed: 'Error: Command 0x804b50fffe9fc8f0/1 genLevelCtrl.moveToLevelWithOnOff({\"level\":3,\"transtime\":0}, {\"sendWhen\":\"immediate\",\"timeout\":10000,\"disableResponse\":false,\"disableRecovery\":false,\"disableDefaultResponse\":false,\"direction\":0,\"srcEndpoint\":null,\"reservedBits\":0,\"manufacturerCode\":null,\"transactionSequenceNumber\":null,\"writeUndiv\":false}) failed (SRSP - AF - dataRequest after 6000ms)'","meta":{"friendly_name":"Bedroom"},"type":"zigbee_publish_error"}'
Zigbee2MQTT:debug 2022-09-22 17:47:11: Received MQTT message on 'zigbee2mqtt/Bedroom/set' with data '{"state":"ON"}'
Zigbee2MQTT:debug 2022-09-22 17:47:11: Publishing 'set' 'state' to 'Bedroom'
Zigbee2MQTT:error 2022-09-22 17:47:17: Publish 'set' 'state' to 'Bedroom' failed: 'Error: Command 0x804b50fffe9fc8f0/1 genOnOff.on({}, {"sendWhen":"immediate","timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (SRSP - AF - dataRequest after 6000ms)'
Zigbee2MQTT:debug 2022-09-22 17:47:17: Error: Command 0x804b50fffe9fc8f0/1 genOnOff.on({}, {"sendWhen":"immediate","timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (SRSP - AF - dataRequest after 6000ms)
Zigbee2MQTT:info  2022-09-22 17:47:17: MQTT publish: topic 'zigbee2mqtt/bridge/log', payload '{"message":"Publish 'set' 'state' to 'Bedroom' failed: 'Error: Command 0x804b50fffe9fc8f0/1 genOnOff.on({}, {\"sendWhen\":\"immediate\",\"timeout\":10000,\"disableResponse\":false,\"disableRecovery\":false,\"disableDefaultResponse\":false,\"direction\":0,\"srcEndpoint\":null,\"reservedBits\":0,\"manufacturerCode\":null,\"transactionSequenceNumber\":null,\"writeUndiv\":false}) failed (SRSP - AF - dataRequest after 6000ms)'","meta":{"friendly_name":"Bedroom"},"type":"zigbee_publish_error"}'
Zigbee2MQTT:debug 2022-09-22 17:51:05: Saving state to file /config/zigbee2mqtt/state.json
Zigbee2MQTT:debug 2022-09-22 17:55:14: Received MQTT message on 'zigbee2mqtt/bridge/request/networkmap' with data '{"routes":false,"transaction":"i0gjj-1","type":"raw"}'
Zigbee2MQTT:info  2022-09-22 17:55:14: Starting network scan (includeRoutes 'false')
Zigbee2MQTT:error 2022-09-22 17:55:32: Failed to execute LQI for 'Coordinator'
Zigbee2MQTT:debug 2022-09-22 17:55:32: Error: SRSP - ZDO - mgmtLqiReq after 6000ms
Zigbee2MQTT:error 2022-09-22 17:55:50: Failed to execute LQI for 'Bedroom'
Zigbee2MQTT:debug 2022-09-22 17:55:50: Error: SRSP - ZDO - mgmtLqiReq after 6000ms
Zigbee2MQTT:debug 2022-09-22 17:56:05: Saving state to file /config/zigbee2mqtt/state.json
Zigbee2MQTT:error 2022-09-22 17:56:09: Failed to execute LQI for 'Outside Lamp'
Zigbee2MQTT:debug 2022-09-22 17:56:09: Error: SRSP - ZDO - mgmtLqiReq after 6000ms
Zigbee2MQTT:error 2022-09-22 17:56:27: Failed to execute LQI for 'Kitchen'
Zigbee2MQTT:debug 2022-09-22 17:56:27: Error: SRSP - ZDO - mgmtLqiReq after 6000ms
Zigbee2MQTT:info  2022-09-22 17:56:27: Network scan finished
Zigbee2MQTT:info  2022-09-22 17:56:27: MQTT publish: topic 'zigbee2mqtt/bridge/response/networkmap', payload '{"data":{"routes":false,"type":"raw","value":{"links":[],"nodes":[{"definition":null,"failed":["lqi"],"friendlyName":"Coordinator","ieeeAddr":"0x00124b00238da1eb","lastSeen":null,"networkAddress":0,"type":"Coordinator"},{"definition":{"description":"TRADFRI LED bulb E12/E14 WW clear 250 lumen, dimmable","model":"LED1935C3","supports":"light (state, brightness), effect, power_on_behavior, linkquality","vendor":"IKEA"},"failed":["lqi"],"friendlyName":"Bedroom","ieeeAddr":"0x804b50fffe9fc8f0","lastSeen":1663801298764,"manufacturerName":"IKEA of Sweden","modelID":"TRADFRIbulbE14WWclear250lm","networkAddress":62412,"type":"Router"},{"definition":{"description":"TRADFRI LED bulb E27 WW clear 250 lumen, dimmable","model":"LED1934G3_E27","supports":"light (state, brightness), effect, power_on_behavior, linkquality","vendor":"IKEA"},"failed":["lqi"],"friendlyName":"Outside Lamp","ieeeAddr":"0xcc86ecfffe80df7a","lastSeen":1663800922654,"manufacturerName":"IKEA of Sweden","modelID":"TRADFRIbulbE27WWclear250lm","networkAddress":4778,"type":"Router"},{"definition":{"description":"TRADFRI bulb E12/E14/E17 WS 450/470/440 lumen, dimmable, white spectrum, opal white","model":"LED1903C5/LED1835C6","supports":"light (state, brightness, color_temp, color_temp_startup), effect, power_on_behavior, linkquality","vendor":"IKEA"},"failed":["lqi"],"friendlyName":"Kitchen","ieeeAddr":"0x804b50fffe496aa7","lastSeen":1663799454674,"manufacturerName":"IKEA of Sweden","modelID":"TRADFRI bulb E14 WS 470lm","networkAddress":15242,"type":"Router"}]}},"status":"ok","transaction":"i0gjj-1"}'
Any advice on what the issue is would be very much appreciated.
Search,on the community for,zigbee problems, and you will find a lot of god advise on zigbee network problems/stability/strength.
First advise, get a long usb extender cable. This defiantly sound as interference with the zigbee signal, from your USB port running the SSD. However search, as E.g. Wi-Fi can also interfere.
