Keep light on when motion is detected
Hi Please could someone help me with this.
I currently have a motion script to turn on a light in my bathroom when motion is detected and goes off after 4 minutes. I would like to keep it on though all the time motion is detected and then turn off 4 minutes after the last motion detected. Is that possible?
This is my current script’s:
bathroom_motion.yaml
` # This automation detects movement from my sensor and turn’s on my under bath light’s if the luminace is below 10.
alias: “Turn on Under Bath Lights with Motion”
  • platform: state
    entity_id: binary_sensor.aeotec_zw100_multisensor_6_sensor_12
    state: ‘on’
    condition:
  • condition: numeric_state
    entity_id: sensor.aeotec_zw100_multisensor_6_luminance_12
    below: 20
    service: script.motion_bathroom`
motion.bathroom.yaml
` sequence:
  • service: script.turn_off
    entity_id: script.motion_bathroom_timer
  • service: switch.turn_on
    entity_id: switch.bath_lights
  • service: script.turn_on
    entity_id: script.motion_bathroom_timer`
bathroom_motion_timer.yaml
` sequence:
  • delay:
    minutes: 4
  • service: switch.turn_off
    entity_id: switch.bath_lights`
MIke
You may have to split up the automation you have into two:
  • an automation to turn on the lights when motion is detected
  • an automation to turn off the lights when no motion is detected for 4 minutes
The trigger of the latter would look like this:
  platform: state
  to: 'off'
  for:
    minutes: 4
Thanks buddy, but I am still non the wiser :frowning: I am very new to all this so most of it is still confusing could you elaborate a little more please.
Mike
I think the example on this page is the easiest. I have it working. https://home-assistant.io/cookbook/turn_on_light_for_10_minutes_when_motion_detected/
Every time when motion is detected, the timer is reset by the script. And the timer will start again
Cheers buddy, This is the actual script I am using and it doesn’t seem to reset.
Ok… strange. Can you show your section from the config yaml here ?
It looks like you are missing the entity_id when you call the script in your bathroom_motion.yaml.
I have it like this:
  service: homeassistant.turn_on
  entity_id: script.timed_lamp
To help you a bit more, my complete config:
kitchen_lights.yaml:
alias: 001 - Turn on kitchen lights when there is movement
  - platform: state
    entity_id: binary_sensor.fibaro_system_fgms001_motion_sensor_sensor_14
    to: 'on'
condition:
  condition: and
  conditions:
    - condition: numeric_state
      entity_id: sensor.fibaro_system_fgms001_motion_sensor_luminance_14
      below: 25
    - condition: state
      entity_id: input_boolean.motion_actief
      state: 'on'
sensors.yaml:
timed_lamp:
alias: "Turn on lamp and set timer"
sequence:
  # Cancel ev. old timers
  - service: script.turn_off
       entity_id: script.timer_off
  - service: light.turn_on
      entity_id: light.keuken
      brightness: 125
  # Set new timer
  - service: script.turn_on
timer_off:
  alias: "Turn off keukenverlichting na 2 min. geen beweging"
  sequence:
    - delay:
        minutes: 2
    - service: light.turn_off
This should work i guess. Although i have some issues with the light turning off when i am in the kitchen. But i think it is due to a parameter of my Fibaro sensor, have to look at it when i have some more time.
P.S. For syntax highlighting large blocks of code, type 3 backticks and then yaml, paste your code and close with three backticks, like this:
‘’‘yaml
blablablacodeblabla
For a single word or line just use one backtick in front and at the end like this: ‘fakecode123’.
@ThinkPad did you ever get this working? I have identical setup (fibaro motion sensor) and script but light keeps turning of while I’m in the kitchen.
Was posting about this here:
@Tyfoon I just have a trigger for on and a timer for off and it works for me. After the 4 mins is up since last detection on the sensor side and it switches to off, the lights go out. Gen 5 aeotech Z wave multisensor - timer settings for sensor are from OZWCP. I copied it the automations from here somewhere - or maybe the cookbooks.
Automation for light on
alias: Kitchen Motion
      platform: state
      entity_id: binary_sensor.kitchen_sensor_2_0
      to: 'on'
    condition:
      entity_id: sun.sun
      value_template: '{{ state.attributes.elevation }}'
      below: 3.5
      entity_id: light.kitchen
And automation timer to switch it off
alias: Kitchen Timer
  platform: state
  to: 'off'
  service: homeassistant.turn_off
Unfortunately not, and as my gf got annoyed of it, i made the light ‘dumb’ again with a button she has to press herself. I’m not sure what went wrong, as it turned on by the sensor fine. But the ‘keep on during motion’ part wasn’t working good.
The problem is “wrong girlfriend”. :wink:
Sorry couldn’t resist.
Im trying to use the code from here …from the examples: “turn on light for 10 min” to send a curl command… my setup:
This is the switch I’m trying to actuate with the automation:
Switches:
  platform: command_line
  switches:
    recording_living_room:
      command_on: 'curl "http://10.0.0.5:8081/allon?ot=2&oid=0"'
      command_off: 'curl "http://10.0.0.5:8081/alloff?ot=2&oid=0"'
      friendly_name: iSpy
My automation code all under automation.yaml and point from configuration.yaml with !include automation.yaml:
## AUTOMATION ##
### Turn on recording when group.family is "not_home" ###
- alias: Turn on iSpy when family is not home
    - platform: state
      entity_id: group.family
      to: 'not home'
    entity_id: script.recording
  recording:
    alias: "Turn on recording and set timer"
    sequence:
      - service: switch.recording_living_room
          entity_id: switch.recording_living_room
      # Set new timer
  timer_off:
    alias: "Turn off recording after 5 minutes"
    sequence:
      - delay:
          minutes: 5
      - service: switch.recording_living_room_off
A few questions:
-its no currently working and I believe its because I need a separate file with “timer_off.yaml” + “recording.yaml” + “tun_on”?
-my actual goal is to use the variables “home” and “not_home” as the trigger? but I have to get it to record before I mess with this part…any advise?
Assuming your switch is defined in your configuration.yaml file, your code should look like this:
switch:
  - platform: command_line
    switches:
        friendly_name: iSpy
Your second bit of code needs to be split as it has both 1 automation and 2 scripts. So your automation.yaml file should look like this:
## AUTOMATION ##
    - platform: state
      to: 'not_home'
And your scripts.yaml file (don’t forget to include it in configuration.yaml) should look like this:
recording:
  sequence:
    - service: switch.turn_on
    # Set new timer
timer_off:
  sequence:
    - delay:
        minutes: 5
    - service: switch.turn_off
This should hopefully make it work:slight_smile:
Turn off light after 4 minutes the last motion detected. Is’t possible in Automation Editor also. Do i create condition type > time ? (Hassbian 0.60.0)
 for:
    minutes: 4
