Hi all!
I’m facing a problem on switch automation: I want to check every minute and switch off the lights (and keep them off if switched on) if time is between 7:30 am and 8 Pm and only If the switch is currently on and if manual override is off (disable_auto_shutdown_lights).
Manually starting the trigger works and switch works as well (I use them everyday to switch lights). I think it’s something related to automation but I can’t find the reason (no error in log)
Here is my automation config (in a separate yaml included with include_dir_merge_list)
- alias: "Lights off between 07:30 and 20:00"
initial_state: "on"
hide_entity: False
platform: time
minutes: "/1"
seconds: 00
condition:
condition: and
conditions:
- condition: time
after: "07:30"
before: "20:00:00"
- condition: state
entity_id: switch.living_room_floor_lamp
state: "on"
- condition: state
entity_id: switch.disable_auto_shutdown_lights
state: "off"
- service: switch.turn_off
- service: notify.telegram_debug
message: "lights_off 07:30 - 20:00"
You’re missing the seconds in your after condition. That might be it.
As an alternative trigger, consider using two different ones. One at 7:30, and one based on the switch going on. That way your militant light turning off will happen nearly instantaneously instead of every minute!
Remove initial_state and hide_entity from the automation. Those don’t belong in the automation. They belong in the configuration. I’m surprised you’re not getting any errors with those in there.
As mentioned by Dolores, be sure to add seconds to your “after” time condition. It should be “07:30:00”.
Well I found the problem and the problem was…me
One of my conditions is
- condition: state
state: "off"
That switch.disable_auto_shutdown_lights doesn’t exists. It is a copy paste error …correct entity is input_boolean.disable_auto_shutdown_lights! After changing with correct entity of course it worked flawlessly.
