Dear all,
Since the Denonavr update I keep losing connection with the receiver and it is driving me nuts. All entities are still there but they do not respond when the receiver is turned on externally or when you try to turn the receiver on in Home Assistant. The receiver itself is reachable through its web-interface: :10443
Inspecting the logs I indeed find that it loses connection:
Update failed.
6:35:54 AM – /usr/local/lib/python3.8/site-packages/denonavr/denonavr.py (ERROR) - message first occurred at 1:41:07 AM and shows up 1770 times
No connection to /goform/AppCommand.xml end point on host 192.168.1.11
6:35:54 AM – /usr/local/lib/python3.8/site-packages/denonavr/denonavr.py (ERROR) - message first occurred at 1:41:07 AM and shows up 3540 times
Getting tone control failed.
Updating denonavr media_player took longer than the scheduled update interval 0:00:10
6:35:54 AM – Media player (WARNING) - message first occurred at 1:41:11 AM and shows up 885 times
Solutions I found say that I should power-cycle the receiver. After, I do a power-cycle and thereafter, restart Home Assistant, indeed the entity works again for some time, until it gets disconnected again and I have to repeat the process. As this happens at random, my Wife Appreciation Factor (WAF) is dropping fast. I have already multiple times removed the integration with similar results.
My system is a NUC running a dockerized Home Assistant 0.117.5.
The Denon AVR 2700x firmware is also the latest: 1200-6225-7061-3085.
Any help or suggestion pointing in the right direction is much appreciated.
Thanks! Dennis
