Keep value when there is no input in Grafana
i have a diagram in Grafana with the set temperature (dashed) for a room and the measured temperature. There is only an input for the set temperature when there is an actual change in the number. What do I need to change in the settings of Grafana so that Grafana keeps the same value when there is no change on the input?
Thanks.
Have you figured out a solution? I am struggling with the same.
no, I didn’t find a solution yet
