Keeper: HA and MQTT service manager
Hi nragon,
sorry but I can’t install your service into my hassio.
When I try to add the serivice I receive the following message:
19-03-29 10:01:32 INFO (MainThread) [hassio.addons.git] Clone add-on https://github.com/nragon/keeper/tree/master/setup/hassio repository
19-03-29 10:01:33 ERROR (MainThread) [hassio.addons.git] Can’t clone https://github.com/nragon/keeper/tree/master/setup/hassio repository: Cmd(‘git’) failed due to: exit code(128)
cmdline: git clone --depth=1 --recursive --shallow-submodules -v https://github.com/nragon/keeper/tree/master/setup/hassio /data/addons/git/625ce890
stderr: 'Cloning into ‘/data/addons/git/625ce890’…
fatal: repository ‘https://github.com/nragon/keeper/tree/master/setup/hassio/’ not found
19-03-29 10:01:33 ERROR (MainThread) [hassio.addons] Can’t load from repository https://github.com/nragon/keeper/tree/master/setup/hassio
Is there another way to install the service via docker?
Thank you
I need the keeper service to monitor HA and mqtt.
I have the docker install.
When I try to add the url: nothing appears.
Please help me to install this add-on
Many thanks for your help.
Best regards
Thierry
Are you able to install the keeper add-on?
The link appears to be invalid in the add in store.
Best regards
Thierry
It appears the Main Developer has stopped maintaining this repo?
Can you confirm this @nragon ?
Hi :slight_smile:
First of all, sorry.
Currently I don’t have time to either improve keeper nor fix dockerfile.
However, I’ll let you know when I do so.
Thank you all.
