Just sharing if anyone needs a service to keep an eye on mqtt and ha
Nuno
Nuno
This is cool. Seems there is a bit more traditional control systems methodologies getting put into HA now.
Good job!
This can seem overzealous but all my sensors and automation rely on MQTT. So I decided to keep an eye on MQTT :). Luckily “System restarts” will never happen
very nice idea - thanks for sharing!
would it be much to ask for a docker installer?
This is quite good.
Currently I have no mechanism to send notifications. There are several implementation we can use to achieve this
No, I’ll update this post when I’ve completed the installer
how do you get these sensor in hass ?
They are automatically added. However, discovery must be enabled on HA. For instance, this is my layout (lovelace)
- type: entities
title: Keeper
entities:
- entity: sensor.kconnectorstatus
icon: mdi:access-point
- entity: sensor.kheartbeaterstatus
icon: mdi:heart-pulse
- entity: sensor.kreporterstatus
icon: mdi:information-outline
- type: section
- entity: sensor.kmqttconnectionstatus
name: MQTT Connection Status
icon: mdi:network
- entity: sensor.kmqttfailedconnections
name: Failed MQTT connections
icon: mdi:sync-alert
- entity: sensor.kmissedheartbeat
name: Missed Heartbeats
icon: mdi:pipe-leak
- entity: sensor.kmqttrestarts
icon: mdi:restart
- entity: sensor.kharestarts
icon: mdi:restart
- entity: sensor.ksystemrestarts
icon: mdi:server
- entity: sensor.klastheartbeat
name: Last Heartbeat
icon: mdi:calendar-clock
- entity: sensor.klastmqttrestart
name: Last MQTT Restart
- entity: sensor.klastharestart
name: Last HA Restart
- entity: sensor.klastsystemrestart
name: Last System Restart
I’ve added a simple dockerfile, not tested yet, didn’t have the time
Thank you for incorporating those features.
A possible additional feature you could consider is adding a time period over which the missed messages/heartbeats is being considered to prevent restarts based on isolated events over an extended period of time.
Actually a restart only happens after 3 missed heartbeats. In the config file you have the heartbeat interval which should be the same for the HA automation. Then you have delay. A heartbeat is considered missed if the difference from last heartbeat and the time we are comparing are greater than Interval + Delay. You can ajust this values however lower values provide a more thorough monitor. Is this the same you were asking?
Assuming I have missed heartbeat yesterday, the second one today and third one tomorrow, the restart will take place tomorrow after the third heartbeat. This would not be critical and may be classified as intermittent. If for example all 3 missed heartbeats occurred within a set 2 minute period, some thing may be amiss and require a restart.
This will not happen because:
TL;DR: A reset happens when between misses an heartbeat arrives
Thank you for clarifying.
Very nice! Just what I was looking for, however I followed the HASSIO instructions on the git page, but the add-on will not load. Used ```
https://github.com/nragon/keeper/tree/master/setup/hassio as the url for the add-on. Any suggestions or help is appreciated.
I’m afraid HASSIO addon is not yet finished, started but not finished. I’ll let you know when done
I appreciate it. And thanks for developing it.
Any luck to get that Hass.io add-on?
By the way, shouldn’t HA’s config use time_pattern
instead of time
- id: keeperheartbeat
initial_state: "on"
platform: time
seconds: "/<numberofseconds>"
