Keeping local development up to date with upstream repo
I am not an expert with git collaboration workflows.
I am developing a Fronius Inverter component.
I made my first commit about that and now I wanted to fetch the upstream dev branch and integrate it with my work.
I have got this git local repos structure:
branch dev (the dev branch of my origin repo forked out of Home Assistant upstream central repo)
branch master_base (checked out from dev)
branch dev_base (checked out from master_base)
I do all my development in dev_base.
When a feature is ready, I commit it and then merge dev_base onto master_base and master_base onto dev.
So, after committing my fronius-commit and merging everything down until both master_base and dev brnaches contain my fronius-commit, I did the following to get the upstream/dev integrated into my work:
git fetch upstream dev          -> fetch upstream/dev branch
git checkout dev                   -> checkout to local dev branch
git rebase upstream/dev       -> rebase local dev branch on top of upstream/dev branch
git checkout master_base    -> checkout to local master_base branch
git rebase dev                       -> rebase local master_base branch on top of local dev branch
git checkout dev_base         -> checkout to local dev_base branch
git rebase master_base        -> rebase local dev_base branch on top of local master_base branch
After that I checkout out to my dev_base branch again to test if everything was working, but launching hass resulted in the following error:
  File "/Users/andyk/Documents/develop/python/virtualenvs/asbox/bin/hass", line 9, in <module>
    load_entry_point('homeassistant', 'console_scripts', 'hass')()
  File "/Users/andyk/Documents/develop/home-assistant/homeassistant/__main__.py", line 358, in main
    args = get_arguments()
  File "/Users/andyk/Documents/develop/home-assistant/homeassistant/__main__.py", line 116, in get_arguments
    import homeassistant.config as config_util
  File "/Users/andyk/Documents/develop/home-assistant/homeassistant/config.py", line 17, in <module>
    from homeassistant.core import valid_entity_id
  File "/Users/andyk/Documents/develop/home-assistant/homeassistant/core.py", line 24, in <module>
    from voluptuous.humanize import humanize_error
ImportError: No module named 'voluptuous.humanize'; 'voluptuous' is not a package
Is it the case that the updated upstream/dev branch needs a voluptuous more recent version?
What does my upstream integration process is missing then?
Am I supposed to rerun any setup procedure after integrating my work with git? If yes, how should it be done?
Or am I missing something else?
Thank you very much,
Andrea
I’m trying to keep things simple. After cloning and changing to the directory of the clone. I do
$ git remote add upstream https://github.com/home-assistant/home-assistant.git
$ script/setup
$ git checkout -b new-feature
$ git pull --rebase upstream dev
I don’t use intermediate branches.
It can happen that dev already contains a new release of a dependency but if you change back to master the downgrade should be done automatically.
Thank you for your answer:slight_smile:
So, beside the different branching strategy (which I will try to simplify a bit as far as our project specs will allow it) I get this two points:
  1. No need for script/setup rerun after rebasing on upstream
The script/setup have to be run just one time, at the beginning of the project, which I already did of course.
  1. Rebase onto master to avoid new dependencies releases problems
Would I better do
git pull --rebase upstream master
to be sure dependencies go on working?
[EDIT]
Nope: I tried that (git pull --rebase upstream master*) and still got a dependency not found related error:
  File "/Users/andyk/Documents/develop/home-assistant/homeassistant/__main__.py", line 363, in main
  File "/Users/andyk/Documents/develop/home-assistant/homeassistant/__main__.py", line 121, in get_arguments
  File "/Users/andyk/Documents/develop/home-assistant/homeassistant/config.py", line 18, in <module>
  File "/Users/andyk/Documents/develop/home-assistant/homeassistant/core.py", line 22, in <module>
    import aiohttp
ImportError: No module named 'aiohttp'
There is still something I am missing:unamused:
Thank you again,
Andrea
