Hello - After upgrading to 2023.2, the Kef integration appears to no longer work. My media player entity says it’s no longer being provided by the Kef integration. I tried deleting it and then named it something different in the yaml config and a new entity was not created.
After reading the breaking changes in this release it doesn’t appear that was disabled, I’m wondering if it was accidentally removed or disabled? Any other trouble shooting advice is appreciated
Yes - exactly as you describe in your first post. I too have tried re-making the media_player: entry and restarting HA, my LSX speakers do not appear, and I see the same entry in the log. It’s not just you!
Same ISSUE here, after the HA update 2023.2 and 2023.2.1. my KEF LSX speakers stopped working.
By the way, I noticed that the KEF component source code didn’t changed for the last couple of months as also my configuration. So the HA update seems to be the suspect.
Fir the record, this is the content of the configuration.yaml
The topic is labelled as ‘Third party integrations’, but that’s not true I think. KEF is part of the HA core ate least for three years or so. I would call is a first party integration.
There has been discussion about this problems on Github, and although most of it goes over my head it does look to me as if a fix is in the pipeline. I’ve no idea of timescales, and I don’t suppose it’s going to be a high priority given that the issue affects a relatively small number of people, but I do think it will happen. Hang in there!
