Kept is a self-hosted inventory of everything you own and where it is, and now it runs as a Home Assistant app: it opens in your sidebar, keeps its own database, and Home Assistant’s backups include it. As the Home Assistant admin you set it up without a setup code.
Install: Settings → Apps → App store → ⋮ → Repositories, add https://github.com/keptinventory/kept, then install Kept. (The README has a one-click “Add to Home Assistant” button too.)
What it does
- Homes, garages and storage units, down to rooms, shelves, drawers and boxes
- A 3D map of each place, and you can start it from a floor plan
- QR labels (label-maker tape too): scan a box to see what’s inside, or count a whole room in one walk
- Receipts, manuals and warranties on each thing, plus Paperless-ngx links
- Due dates: warranties, services and schedules, with a calendar
- Vehicles: service history, readings and the next service
- Lending: who has what and when it’s due back
- Low stock on things you use up
- Moving mode: pack, track and unpack boxes
- Import from Homebox or a spreadsheet
- Optional AI: walk a room with your camera and it drafts what it sees, ask the assistant, or use the MCP server
- Works offline on your phone, with several people and locations, in five languages
With Home Assistant
The Kept integration (HACS) brings what’s overdue, due and lent out, your car’s next service and a due-dates calendar into dashboards and automations, and can log readings back: GitHub - keptinventory/kept-homeassistant: Kept for Home Assistant · GitHub
- App docs: kept/homeassistant/kept/DOCS.md at 20b4ce49cce860c0609a8fe1a3b6f11cf36e614c · keptinventory/kept · GitHub
- Source: GitHub - keptinventory/kept: Self-hosted, open-source inventory of everything you own and where it is. AI assistant and MCP server built in. · GitHub (AGPL-3.0)
Kept 1.14.3. Feedback is very welcome, especially from Companion app users: Test the Kept Home Assistant app in the Companion app · Issue #361 · keptinventory/kept · GitHub
