Kernel doesn't detect Aeotec Z-Stick Gen5 on Raspberry Pi 4
After rebooting my system Z-wave is not working anymore! I noticed there is no /dev/ttyACM0 anymore.
$ ls -l /dev/tty*
crw-rw-rw-    1 root     root        5,   0 Feb  9 08:07 /dev/tty
crw-rw----    1 root     audio     204,  64 Feb  9 08:07 /dev/ttyAMA0
Also, the device is not shown with lsusb.
$ lsusb
Bus 001 Device 001: ID 1d6b:0002
Bus 001 Device 002: ID 2109:3431
Bus 002 Device 001: ID 1d6b:0003
Bus 001 Device 003: ID 1781:0c30
There is nothing in dmesg when I connect the device to the USB port indicating it is not detected by the kernel. When connecting the USB stick to my laptop everything works as expected, so there is nothing wrong with the stick itself.
The USB stick uses cdc_acm.ko driver. Not sure if it is compiled in to the kernel or as module? Anyways, lsmod doesn’t show it.
I’m a bit confused, since this has been working perfectly until the reboot. Any clues anyone?
I’m running on a Raspberry Pi 4.
$ hassio info
arch: armv7
channel: stable
hassos: "3.9"
homeassistant: 0.105.2
hostname: hassio
logging: info
machine: raspberrypi4
supervisor: "199"
supported_arch:
- armv7
- armhf
timezone: Europe/Stockholm
 $ hassio hw info
audio:
  "0":
    devices:
    - chan_id: "0"
      chan_type: digital audio playback
    - chan_id: "1"
    - chan_id: "2"
    name: bcm2835_alsa - bcm2835 ALSA
    type: ALSA
disk:
- /dev/mmcblk0
- /dev/mmcblk0p3
- /dev/mmcblk0p7
- /dev/mmcblk0p4
- /dev/mmcblk0p2
- /dev/mmcblk0p5
- /dev/mmcblk0p6
- /dev/mmcblk0p8
- /dev/mmcblk0p1
gpio:
- gpiochip0
- gpiochip100
- gpiochip504
input: []
serial:
- /dev/ttyAMA0
There’s a known issue with the Aeotec stick and the Raspberry Pi 4… try using a USB 2 hub
https://www.raspberrypi.org/forums/viewtopic.php?f=28&t=245031#p1502030
Great! That was it! I connected it through a USB hub and now it’s detected!
It’s weird that I initially had it working without the hub, but I guess that was pure luck maybe?
Thanks for the help!
hi which hub did you bought
having the same issue
Is this still required with HASS OS 5.x? I’m referring to the need to use a hub to connect a Aeotec Z-Stick
It’s not a software but a hardware issue. So yes, unless you bought one of the new fixed versions of the stick or you fixed it yourself with a little hardware mod.
https://community.home-assistant.io/t/sticky-aeotec-z-stick-gen5-raspberry-pi4
Hi @HeyImAlex, what is the hardware mod? Are we talking about soldering or something? Thank you for the quick response. Just curious what my options are to get rid of the USB hub,.
I edited my reply above with the link. There is an incorrect pullup resistor you need to fix. There is a little SMD soldering involved.
