I am having a weird issue logging into and working on my Hassio on my raspberry pi with chrome. This just started a few days ago and I’m not sure where to ask. I’m pretty sure it’s a Chrome issue. When I go to enter anything via the keyboard into Home Assistant many of the keypresses wont record into home assistant. For example, when I try to type Detector, all I will get is Do. Certain letters will type if I capitalize them. Even the login page I have to type my login into notepad and copy/paste into Home Assistant.
I have cleared the cache on chrome, rebooted etc. and tried numerous other things. This ONLY happens on home assistant.
Can anyone point me in the right direction to fix this
I have the same problem with Safari and Chrome with my MacBook pro (OS 10.15.3). With the Mac Pro (OS 10.15.2) everything is okay. The only difference i see is the MacOS Version.
Today I update my Mac Pro to OS 10.15.3. After the update I have also no letter problems.
There must be another difference between my Mac Pro (works correct) and the MacBook Pro (works incorrect)!
If you’re reading this, check your browser extensions! I had one called Dynamo- disabled it and suddenly, no more lost keystrokes!
This explain why people above reported the issue happening/not happening in different combinations of browsers- I never use Chrome so it didn’t have any extensions but I had a few enabled in Safari.
A guess is that there’s some shared (or conflicting) Javascript library?
Anyway, hat tip to JC (no, not that one) for working this one out.
