KeyError: 'sf' - When configuring Homekit Controller
Hello!
I am running HA in Docker Compose with host networking. I have a HomeKit Bridge running with no problems. However, I would like to set up a HomeKit Controller to get my Ecobee to use the local API. Every time I go to the integrations page and go to add the component, I am taken back to the " Set up a new integration" page. The log shows the following:
2020-07-27 16:55:19 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
  File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 128, in async_init
    result = await self._async_handle_step(
  File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 201, in _async_handle_step
    result: Dict = await getattr(flow, method)(user_input)
  File "/usr/src/homeassistant/homeassistant/components/homekit_controller/config_flow.py", line 161, in async_step_zeroconf
    status_flags = int(properties["sf"])
KeyError: 'sf'
2020-07-27 16:56:10 ERROR (MainThread) [aiohttp.server] Error handling request
  File "/usr/local/lib/python3.8/site-packages/aiohttp/web_protocol.py", line 418, in start
    resp = await task
  File "/usr/local/lib/python3.8/site-packages/aiohttp/web_app.py", line 458, in _handle
    resp = await handler(request)
  File "/usr/local/lib/python3.8/site-packages/aiohttp/web_middlewares.py", line 119, in impl
    return await handler(request)
  File "/usr/src/homeassistant/homeassistant/components/http/real_ip.py", line 39, in real_ip_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 73, in ban_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 127, in auth_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 129, in handle
    result = await result
  File "/usr/src/homeassistant/homeassistant/components/config/config_entries.py", line 112, in post
    return await super().post(request)
  File "/usr/src/homeassistant/homeassistant/components/http/data_validator.py", line 60, in wrapper
    result = await method(view, request, *args, **kwargs)
  File "/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py", line 69, in post
    result = await self._flow_mgr.async_init(
  File "/usr/src/homeassistant/homeassistant/components/homekit_controller/config_flow.py", line 91, in async_step_user
    status_flags = int(host.info["sf"])
KeyError: 'sf'
2020-07-27 17:00:03 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
KeyError: 'sf'
I have tried the following:
None of these options have worked.
Anyone have any ideas of what I should try? I’m a bit stuck at this point
