Hello, I’m trying to read incoming data using:
Hostname | raspberrypi
System | Raspbian GNU/Linux 10 (buster)
Docker version | 19.03.12
Appdeamon - 4.0.3
the code I’m using is: I’ve snipped out the bulk of the pre serial to save your eyes
def run_every_Serial(self, kwargs):
#set up serial load data etc done here before....#
if ser.isOpen():
ser.write(data)
ser.flush()
try:
#read
doc=ser.readline()
buttonUpdate=1
sensorUpdate=1
except Exception as e:
self.log("Error : try to parse an incomplete message")
pass
if buttonUpdate==1:
self.updateButtons(doc)
def updateButtons(self, doc):
self.log("2. Recieved: %s\n",doc)
self.log("3: %s",doc['pbr_auto_man'])
self.log("4: %s",doc['pbr_start_stop'])
self.log("5: %s",doc['light_auto_man'])
self.log("6: %s",doc['lp_1'])
from the Appdaemon log, I can see that message has been received. the issue is when I call the key’s every second key throws the following error below:
Unsure as to why I’ve tried including .decode()/.decode(‘utf-8’)/.decode(‘ascii’).
if I comment it out, self.log(5… ) will be fine and self.log(6…) will have the error.
##self.log("4: %s",doc['pbr_start_stop'])
error:
2020-08-19 02:55:25.511764 INFO serialArduinoPi: 3: 1
2020-08-19 02:55:25.512433 WARNING serialArduinoPi: ------------------------------------------------------------
2020-08-19 02:55:25.512980 WARNING serialArduinoPi: Unexpected error in worker for App serialArduinoPi:
2020-08-19 02:55:25.513588 WARNING serialArduinoPi: Worker Ags: {'id': '0484a5ce91624f8da1f194c7f7ae55ea', 'name': 'serialArduinoPi', 'objectid': '0d49c618014d45b8b782cfdceaab2c73', 'type': 'scheduler', 'function': <bound method ArduinoPiComms.run_every_Serial of <whyIsSerialDumb.ArduinoPiComms object at 0xb542ed60>>, 'pin_app': True, 'pin_thread': 0, 'kwargs': {'interval': 1, '__thread_id': 'thread-0'}}
2020-08-19 02:55:25.514290 WARNING serialArduinoPi: ------------------------------------------------------------
2020-08-19 02:55:25.515130 WARNING serialArduinoPi: Traceback (most recent call last):
File "/usr/lib/python3.8/site-packages/appdaemon/threading.py", line 766, in worker
funcref(self.AD.sched.sanitize_timer_kwargs(app, args["kwargs"]))
File "/config/appdaemon/apps/whyIsSerialDumb.py", line 49, in run_every_Serial
File "/config/appdaemon/apps/whyIsSerialDumb.py", line 219, in updateButtons
KeyError: 'pbr_start_stop'
reading from log:
2020-08-19 02:53:05.072693 INFO serialArduinoPi: 1. Outgoing: b'{"pbr_auto_man": 1, "pbr_start_stop:": 1, "light_auto_man": 1, "lp_1:": 1, "lp1_1": 0, "lp1_2:": 0, "lp1_3": 0, "lp1_4:": 0, "lp_2": 1, "lp2_1:": 0, "lp2_2": 0, "lp2_3:": 0, "lp2_4:": 0, "temp_auto_man": 1, "temp_start_stop:": 1, "air_auto_man": 1, "air_start_stop": 1, "dose_auto_man": 1, "dose_start_stop": 0, "dose_ph_up": 1, "dose_ph_down": 1, "dose_nut": 1, "dose_sample": 1, "dose_top_up": 1, "harvset_auto_mann": 0, "harvest_start_stop": 0, "pbr_cycle_length": 0.0, "pbr_cycle_remaining": 0.0, "lux_sv": 0.0, "ph_sv": 5.0, "do_sv": -6.3, "temp_sv": 12.8, "turbity_sv": -10.0, "coil1_sv": -10.0, "coil2_sv": -10.0, "chiller_temp_sv": -10.0, "co2_in_sv": -10.0, "co2_out_sv": -10.0, "pressure_sv": 0.0, "press_valve_sv": 100.0, "dump1_valve_sv": 0.0, "dump2_valve_sv": 0.0}'
2020-08-19 02:53:05.500699 INFO serialArduinoPi: 2. Recieved: {'pbr_auto_man': 1, 'pbr_start_stop:': 1, 'light_auto_man': 1, 'lp_1:': 1, 'lp1_1': 0, 'lp1_2:': 0, 'lp1_3': 0, 'lp1_4:': 0, 'lp_2': 1, 'lp2_1:': 0, 'lp2_2': 0, 'lp2_3:': 0, 'lp2_4:': 0, 'temp_auto_man': 1, 'temp_start_stop:': 1, 'air_auto_man': 1, 'air_start_stop': 1, 'dose_auto_man': 1, 'dose_start_stop': 0, 'dose_ph_up': 0, 'dose_ph_down': 0, 'dose_nut': 0, 'dose_sample': 0, 'dose_top_up': 0, 'harvset_auto_mann': 0, 'harvest_start_stop': 0, 'pbr_cycle_length': 0, 'pbr_cycle_remaining': 0, 'lux_sv': 0, 'ph_sv': 5, 'do_sv': -6.3, 'temp_sv': 12.8, 'turbity_sv': -10, 'coil1_sv': -10, 'coil2_sv': -10, 'chiller_temp_sv': -10, 'co2_in_sv': -10, 'co2_out_sv': -10, 'pressure_sv': 0, 'press_valve_sv': 100, 'dump1_valve_sv': 0, 'dump2_valve_sv': 0}
