I haven’t made any changes to Keymaster, but started getting this error today:
The automation "keymaster_front_door User Notifications" (`automation.keymaster_front_door_user_notifications`) has an action that calls an unknown service: `script.keymaster_front_door_manual_notify`.
This error prevents the automation from running correctly. Maybe this service is no longer available, or perhaps a typo caused it.
To fix this error, [edit the automation](/config/automation/edit/keymaster_front_door User Notifications) and remove the action that calls this service.
Click on SUBMIT below to confirm you have fixed this automation.
I also see this message in the HA log:
2022-09-07 20:45:05.163 ERROR (MainThread) [homeassistant.components.automation.keymaster_front_door_user_notifications] keymaster_front_door User Notifications: Error executing script. Service not found for call_service at pos 1: Unable to find service script.keymaster_front_door_manual_notify
I installed the latest HA Core, 2022.9.0 today, but don’t see why that would have caused this error. I also installed InfluxDB and Grafana. Again, don’t see the relation.
It tells me to edit the automation, but this automation is not in the automations.yaml so there is nothing I can do with it. Any thoughts on what to do? Do I need to delete and re-install keymaster?
Thanks, David
