Delfairen
(Delfairen)
October 22, 2024, 4:28pm
1
I had a power failure recently and when I regained power all the Schlage locks in the house needed all the codes resetting/readding through the Keymaster integration as everything showed disconnected and zero codes worked on any door (this I will address on the GitHub as this seems like it is a serious issue and it should not be clearing codes if it is not able to see the HA instance) this worked on all but one lock. I can still lock and unlock the lock through HA but Keymaster can’t set or rest any of the slots. I have tried both the default zwave integration and the zwavejs addon without any success.
I have read the BE469 have issues but I had this setup previously so I am not sure what is wrong.
Are you looking at the ZWAVE logs? Are you seeing any error?
Delfairen
(Delfairen)
October 22, 2024, 6:14pm
3
I looked at the ones I could find but they were truncated so I was not sure the best place to look. I did get one message about not being able to check firmware, but I was not sure that would matter. Where is the correct place to check the zwave logs?
If you’re using ZWAVE_JS, Settings then Addon, select ZWAVE_JS, then the log tab.
Delfairen
(Delfairen)
October 23, 2024, 5:08pm
5
That is where I am but no scroll bar to view all messages. This is as much as I get.
· AddNodeToNetwork (0x4a)
· RemoveNodeFromNetwork (0x4b)
· AddControllerAndAssignPrimary (0x4c)
· AddPrimaryController (0x4d)
· SetLearnMode (0x50)
· AssignSUCReturnRoute (0x51)
· RequestNetworkUpdate (0x53)
· SetSUCNodeId (0x54)
· DeleteSUCReturnRoute (0x55)
· GetSUCNodeId (0x56)
· SendSUCNodeId (0x57)
· ExploreRequestInclusion (0x5e)
· RequestNodeInfo (0x60)
· RemoveFailedNode (0x61)
· IsFailedNode (0x62)
· ReplaceFailedNode (0x63)
· UNKNOWN_FUNC_UNKNOWN_0x66 (0x66)
· UNKNOWN_FUNC_UNKNOWN_0x67 (0x67)
· FirmwareUpdateNVM (0x78)
· GetRoutingInfo (0x80)
· LockUnlockLastRoute (0x90)
· GetPriorityRoute (0x92)
· SetPriorityRoute (0x93)
· UNKNOWN_FUNC_UNKNOWN_0x98 (0x98)
· undefined (0xb4)
· EnableWatchdog500 (0xb6)
· DisableWatchdog500 (0xb7)
· KickWatchdog500 (0xb8)
· UNKNOWN_FUNC_UNKNOWN_0xB9 (0xb9)
· UNKNOWN_FUNC_RF_POWERLEVEL_GET (0xba)
· GetLibrary (0xbd)
· SendTestFrame (0xbe)
· GetProtocolStatus (0xbf)
· StartWatchdog (0xd2)
· StopWatchdog (0xd3)
· SetMaximumRoutingAttempts (0xd4)
· undefined (0xee)
· undefined (0xef)
2024-10-23T17:00:27.812Z CNTRLR querying additional controller information...
2024-10-23T17:00:27.884Z CNTRLR received additional controller information:
Z-Wave API version: 5 (legacy)
Z-Wave chip type: ZW050x
node type Controller
controller role: primary
controller is the SIS: true
controller supports timers: false
Z-Wave Classic nodes: 1, 2, 3, 4, 11
2024-10-23T17:00:27.884Z CNTRLR querying version info...
2024-10-23T17:00:27.900Z CNTRLR received version info:
controller type: Static Controller
library version: Z-Wave 4.05
2024-10-23T17:00:27.900Z CNTRLR querying protocol version info...
2024-10-23T17:00:27.913Z CNTRLR received protocol version info:
protocol type: Z-Wave
protocol version: 4.5.0
2024-10-23T17:00:27.915Z CNTRLR querying controller capabilities...
2024-10-23T17:00:27.928Z CNTRLR received controller capabilities:
controller role: Primary
is the SUC: true
started this network: true
SIS is present: true
was real primary: true
2024-10-23T17:00:27.930Z CNTRLR supported Z-Wave features:
2024-10-23T17:00:27.933Z CNTRLR querying controller IDs...
2024-10-23T17:00:27.944Z CNTRLR received controller IDs:
home ID: 0xd6368055
own node ID: 1
2024-10-23T17:00:27.945Z CNTRLR finding SUC...
2024-10-23T17:00:27.956Z CNTRLR This is the SUC
2024-10-23T17:00:27.956Z CNTRLR setting serial API timeouts: ack = 1000 ms, byte = 150 ms
2024-10-23T17:00:27.967Z CNTRLR serial API timeouts overwritten. The old values were: ack = 1000 ms, byte = 15
0 ms
2024-10-23T17:00:28.119Z CNTRLR [Node 001] Embedded device config loaded
2024-10-23T17:00:28.139Z CNTRLR [Node 002] Embedded device config loaded
2024-10-23T17:00:28.155Z CNTRLR [Node 003] Embedded device config loaded
2024-10-23T17:00:28.164Z CNTRLR [Node 004] Embedded device config loaded
2024-10-23T17:00:28.184Z CNTRLR Interview completed
Starting server on <all interfaces>:3000
2024-10-23T17:00:28.216Z CNTRLR [Node 001] The node is alive.
2024-10-23T17:00:28.216Z CNTRLR [Node 001] The node is ready to be used
2024-10-23T17:00:28.218Z CNTRLR Interviewing nodes and/or determining their status: 2, 3, 11, 4
2024-10-23T17:00:28.219Z CNTRLR » [Node 002] pinging the node...
2024-10-23T17:00:28.353Z CNTRLR » [Node 003] pinging the node...
2024-10-23T17:00:28.356Z CNTRLR » [Node 011] pinging the node...
2024-10-23T17:00:28.360Z CNTRLR » [Node 004] pinging the node...
ZwaveJS server listening on <all interfaces>:3000
2024-10-23T17:00:28.399Z CNTRLR [Node 002] The node is alive.
2024-10-23T17:00:28.400Z CNTRLR [Node 002] The node is ready to be used
2024-10-23T17:00:28.401Z CNTRLR « [Node 002] ping successful
2024-10-23T17:00:29.656Z CNTRLR [Node 003] The node is alive.
2024-10-23T17:00:29.657Z CNTRLR [Node 003] The node is ready to be used
2024-10-23T17:00:29.658Z CNTRLR « [Node 003] ping successful
2024-10-23T17:00:30.930Z CNTRLR [Node 011] The node is alive.
2024-10-23T17:00:30.931Z CNTRLR [Node 011] The node is ready to be used
2024-10-23T17:00:30.931Z CNTRLR « [Node 011] ping successful
2024-10-23T17:00:32.185Z CNTRLR [Node 004] The node is alive.
2024-10-23T17:00:32.186Z CNTRLR [Node 004] The node is ready to be used
2024-10-23T17:00:32.187Z CNTRLR All nodes are ready to be used
2024-10-23T17:00:32.188Z CNTRLR « [Node 004] ping successful
New client
Delfairen
(Delfairen)
October 23, 2024, 5:33pm
6
I’m not sure but I think when I do anything on the lock through Keymaster it puts a line in the log stating New Client.
I also now know node 2 is the smart plug, node 4 is the front door but this is not very clear, and I wish there was a good way to figure out the nodes number to name.
