itnassol
(Andrew)
1
I have keymaster and it send verbal notifications to various speakers around the house, or at least it did.
Here’s the code in scripts that I have been using and up until today was working perfectly.
![File_editor_–Home_Assistant-_2022-09-13_17.50.43](https://community-assets.home-assistant.io/original/4X/c/9/6/c9678f3053b4d22ea821180d4aafc613664ed5bd.png)
When some one used there code to unlock the door it would say “xxx is home” or “xxx is here”
Now it does nothing an throws up this warning.
![Settings_–Home_Assistant-_2022-09-13_17.50.29](https://community-assets.home-assistant.io/original/4X/7/a/0/7a018976dc1d0529e33144dc948dfae6f1c79064.png)
Any ideas, I’ve been on this for hours and the fact that it worked is so frustrating.
Thanks in advance.
Check if the service is renamed to something else as old_name_1, it happened to me for cover service i implemented using script
itnassol
(Andrew)
3
Thank you for that, I am very new to HA, where would I find those services? Thanks
itnassol
(Andrew)
4
Cracked it, changed the volume up code and it now works… New code is
keymaster_front_door_lock_manual_notify:
mode: parallel
sequence:
- service: media_player.volume_set
volume_level: 0.7
entity_id:
- media_player.dining_room_speaker
- media_player.living_room_display
- media_player.office_display
- media_player.spa_room_speaker
- service: tts.cloud_say
entity_id:
message: "{{ message }}"
Thank you
