KeyMaster Z-Wave lock manager and scheduler
Follow these steps to create the view.
Thank you for your help… can you please tell what I’m doing wrong?
I’ve attached some screenshots.
Or, maybe I can give you teamviwer credential and some beer? :slight_smile:
You’re also missing this step.
Thanks…
step by step with your help (hopefully) we’ll get it done :slight_smile:
I managed to get Lovelace dashboard look ok but it doesn’t work properly.
When I add a pin code - it registers in the lock, but then a few seconds later deletes itself.
I also tried to set date range for it to be valid but it just clears the code straight away…
Like there is a 5 second refresh or something
PLEASE help :slight_smile:
Never heard of such a thing.
Wanted to make you a video and found an issue…
It happens if I add a name into the name field…
If I leave it blank or if I enter numbers there - its ok… if I enter letters into the name field - it resets
Now I need to figure out how to automate it so it generates and resets the codes for users…
Short rental properties…
Used to use Rboys RLA… but samsungs messed something and it won’t work now (
Try name first THEN pin.
I honestly don’t recall the workings off the top of my head, I just “set it and forget it” :stuck_out_tongue:
I am having an issue where when I manually lock or unlock my Schlage lock, I get a notification (set up via pushover). It’s just the basic notification script shown below.
keymaster_frontdoorlock_manual_notify:
  mode: parallel
  sequence:
  - service: notify.pushover
      title: '{{ title }}'
      message: '{{ message }}'
My problem is that my notifications always show the opposite of what is actually happening. When I unlock the door, it says I am locking it, and when I lock it, it says I am unlocking it.
My guess is that this is something to do with it being a right hand vs left hand open, which I think I had to setup when I first installed the lock.
This didn’t happen when I first installed keymaster a year or so ago, I think it must have happened with one of the updates in the last few months, but I didn’t notice exactly when it started.
Anyone else heard of or having this problem, or ideas of how to fix?
Do you know, by any chance, why in Zwave logs time is different from my Home Assistant?
Its -2 hours comparing to server setup… so I don’t know what time to set for locks “check-in” “check-out” :slight_smile:
Just to show my issue. You can see that Home Assistant shows the lock/unlock correctly, and my notification shows the opposite.
Found it here Z-wave JS log file time stamps are wrong - #3 by freshcoast
Your lock sent the message, so I don’t know.
Listen to the zwave_js_notification events to see if they’re also saying unlocked when locked.
Thanks,
I manually unlocked the door, and below is what showed up in the events. You will see that “boltStatus” went from locked to unlocked, and the last event on the bottom says “Manual Unlock Operation”, so those are correct. However, as with previously, my notification in Home Assistant (Pushover) says "Manual Lock (Slot 1 Default).
2023-02-24T18:57:59.383Z - VALUE UPDATED
Arg 0:
└─commandClassName: Door Lock
└─commandClass: 98
└─property: currentMode
└─endpoint: 0
└─newValue: 0
└─prevValue: 255
└─propertyName: currentMode
2023-02-24T18:57:59.387Z - VALUE UPDATED
Arg 0:
└─commandClass: 98
└─property: outsideHandlesCanOpenDoor
└─endpoint: 0
└─newValue: false, false, false, false
└─prevValue: false, false, false, false
└─propertyName: outsideHandlesCanOpenDoor
2023-02-24T18:57:59.391Z - VALUE UPDATED
Arg 0:
└─commandClass: 98
└─property: insideHandlesCanOpenDoor
└─endpoint: 0
└─propertyName: insideHandlesCanOpenDoor
2023-02-24T18:57:59.397Z - VALUE UPDATED
Arg 0:
└─commandClass: 98
└─property: doorStatus
└─endpoint: 0
└─newValue: open
└─prevValue: open
└─propertyName: doorStatus
2023-02-24T18:57:59.401Z - VALUE UPDATED
Arg 0:
└─commandClass: 98
└─property: boltStatus
└─endpoint: 0
└─newValue: unlocked
└─prevValue: locked
└─propertyName: boltStatus
2023-02-24T18:57:59.404Z - VALUE UPDATED
Arg 0:
└─commandClass: 98
└─property: latchStatus
└─endpoint: 0
└─newValue: open
└─prevValue: open
└─propertyName: latchStatus
2023-02-24T18:57:59.550Z - VALUE UPDATED
Arg 0:
└─commandClassName: Notification
└─commandClass: 113
└─property: alarmType
└─endpoint: 0
└─newValue: 22
└─prevValue: 21
└─propertyName: alarmType
2023-02-24T18:57:59.554Z - VALUE UPDATED
Arg 0:
└─commandClass: 113
└─property: alarmLevel
└─endpoint: 0
└─newValue: 1
└─prevValue: 1
└─propertyName: alarmLevel
2023-02-24T18:57:59.561Z - VALUE UPDATED
Arg 0:
└─commandClass: 98
└─endpoint: 0
└─newValue: 0
└─prevValue: 0
2023-02-24T18:57:59.563Z - NOTIFICATION
Arg 0:
113
Arg 1:
└─type: 6
└─event: 2
└─label: Access Control
└─eventLabel: Manual unlock operation
Dev-tools → Events
Enter zwave_js_notification into the “Event to subscribe to” and press Start Listening
Then go toggle your lock see what outputs.
Ok, so just locked the door again. zwave_js_notification appears to be sending the correct info (lock), but notification is showing unlock.
event_type: zwave_js_notification
  domain: zwave_js
  node_id: 16
  home_id: 4089985283
  device_id: 16b4f114df0ec42209f2b09cdca6292c
  command_class: 113
  command_class_name: Notification
  type: 6
  event: 1
  event_label: Manual lock operation
  parameters: {}
origin: LOCAL
time_fired: "2023-02-24T20:03:40.882871+00:00"
context:
  parent_id: null
  user_id: null
edit: image attached below
Next test, listen to keymaster_lock_state_changed see what it’s saying when you do that.
I have some Alfred DB1 Zwave locks. They have been working well except notifications. I can get a notification using the top circles.
It seems the alarm type never changes, I thought it used to work with smartthings but could be wrong as I used to have a Schlage lock there and that may have been the one that worked. Is this a limitation of the lock or a problem with z-wave js
thanks
Craig
I have it posted as its own topic but no traction on it. I hate adding to this thread because it is really long, and I will be the first to admit I have not read all 2,757 replies, but here is the issue I am having and until I get the entities to show up, I am not working on the dashboard.
My BE469 lock on my front door went through correctly and I have the entities. No problem.
I have two BE469ZPs (Side door and garage entry door) and I tried to make the Front Door the master and that bombed terribly so I made each one as their own and the wizard at least ran but the entities show unavailable so something is not right, but at least the “Network” entity shows up OK.
I know the security and basic setup on these locks is a lot different since the ZPs have QR Codes/PINs unlike the BE469.
BE469:
BE469ZP (and they are both like this):
Thank you in advance, everybody.
Re-interview your locks until the Usercode command class populates in ZwaveJS-UI
Just using the normal Z-WaveJS right now. I know at some point I should migrate over to ZwaveJS-UI but I want to make sure I get it done right. I kicked off at least 5 and now Z-Wave does not know what they are, anymore.
