KeyMaster Z-Wave lock manager and scheduler
This really ought to be built-into HA as a native integration.
Thatā€™s kind of you to say so but I donā€™t think this is likely to occur. This package is essentially a GUI front end, nothing more.
Hey! Iā€™ve updated to the latest version, a couple of errors on the new version: here they are:
  • maindoor_conditional_notify: Error executing script. Service not found for call_service at pos 2: Unable to find service script/maindoor_manual_notify
  • maindoor Notifications: Already running
  • maindoor Notifications: Error executing script. Service not found for call_service at pos 1: Unable to find service script/maindoor_manual_notify
  • While executing automation automation.maindoor_notifications
This has been removed from the package to allow customizing the notification and as not all notification services utilize the same formatting variables.
Hereā€™s an example you can modify and place in your own scripts:
frontdoor_manual_notify:
  mode: parallel
  sequence:
    - service: notify.phones
      data_template:
        title: "{{ title }}"
        message: "{{ message }}"
Itā€™s fine to ignore this, this is due to the new scripting engine updates.
Same as point 1
Hello, I hope someone can point me in the right direction with my issue. Iā€™m trying to run the latest OZW beta 0.9 and have followed the setup directions but cannot get the lovelace frontend to generate even using the setup.sh script.
Here is what I get when I try running the script.
Annotation 2020-08-24 184330
I seem to have a problem with the ozw-beta version. These automations do not trigger at startup thus the booleans are not set thus the lock manager does not update/clear codesā€¦
Zwave_loaded_Start_System
For my Kwikset lock, I had to go to Devices, search for ozw (or from OpenZWave integration click Devices which gives you the same filtered view) and select the lock. In there I found three disabled ā€œalarmā€ entities from OZW. Once I enabled them and restarted, I was able to pick them in lockmanager setup for my garage door.
Unfortunately, my Vision ZM1701 does not have those ALARM_CLASS entities so I just picked another to satisfy the setup requirementsā€¦
Removing an integration does not remove the config/packages/lockmanager/XXXXXX folder.
I had to rm -r XXXXXX so I could start over.
Also, the entities created do not get removed; I had to manually remove those as wellā€¦
I wish I could get as far as getting that with the latest ozw build. I have followed the setup but cannot get the lovelace yaml to generate into the packages/lock-manager folder
Install lock-manager v0.0.0-ozw via HACS Integrations.
Create input_booleans, binary_sensors, automations and scripts listed under Additional Setup.
Restart HA.
The in HA: Configuration, Integrations, add ā€œLock Managerā€ which will automatically take you into setting up your first lock which will populate config/packages/<your_lockname>.
Repeat the add integration for additional locksā€¦
Iā€™m trying to figure out how best to handle these automations and scripts since they were meant for the Z-Wave integration and not OpenZWaveā€¦
- alias: homeassistant start-up
  initial_state: true
    platform: homeassistant
    event: start
    - service: script.turn_on
      entity_id: script.customstartup
- alias: Zwave_loaded_Start_System
  initial_state: true
    - platform: event
      event_type: zwave.network_ready
    - platform: event
      event_type: zwave.network_complete
    - platform: event
      event_type: zwave.network_complete_some_dead
      entity_id: script.system_cleanup
and likewise, add the following to your scripts:
system_cleanup:
  sequence:
    #- service: homekit.start If you use homekit, uncomment this statement
      entity_id: input_boolean.system_ready
        entity_id: 'input_boolean.allow_automation_execution'
customstartup:
  sequence:
    - service: input_boolean.turn_off
      # You can add other "startup" code here if you wish
Will regular z-wave integration still be updated?
Trying to decide whether I want to just go with the OpenZWave to begin with. I was thinking Iā€™d wait until it comes out of beta before I switch over. Thoughts? :slight_smile:
From what I understand, the old integration is no longer being maintained.
Iā€™m switching from HomeSeer where Z-Wave has been the mainstay for 25+years.
The only issue Iā€™m currently having is with HAB iblinds which Iā€™ve started writing a custom device ā€˜handlerā€™ for and a Monoprice branded Good Way RGBW controller which I donā€™t have working yetā€¦
Kwikset Smartcode OZW ProductCodes: 0x0090 0x0001 0a001
No notification received for keypad unlockā€¦
See this post.
Decided to try to add this thru OpenZwave using HACS. Any idea why Iā€™d be getting a ā€œuser input malformedā€ error when trying to add the integration? All fields are populated except ā€œuser code sensorā€ and ā€œaccess control sensorā€ which have no pull down menus attached.
Never mind, I see above :rofl: Iā€™ll look into creating a dummyā€¦
If thereā€™s an easy way to do this, please let me know!
If your sensors are missing, youā€™ll want to enable them in the device.
That doesnā€™t work for me. I am running OpenZWave 1.6 on another box (not integrated with HA) thus itā€™s status is already ā€œonā€ and does not trigger the automation at HA startupā€¦
I think I need a HomeAssistant startup automation with condition if ozw status is on then enable the booleansā€¦
Iā€™ve setup this automation instead:
- id: 712a904051494d49824430c4ff93a387
  alias: HA Startup - Set Door Lock Booleans
  - event: start
  condition: []
  - condition: state
    entity_id: binary_sensor.ozw_network_status
    state: 'on'
  - data:
      entity_id: input_boolean.allow_automation_execution
  - data:
  - condition: state
    state: 'off'
  - data:
  - data:
  initial_state: true
  mode: single
As well as this:
- id: '1598320765664'
  alias: OpenZwave State Changed
  description: ''
  - entity_id: binary_sensor.ozw_network_status
    platform: state
  condition: []
  - condition: state
    state: 'on'
  - entity_id: input_boolean.allow_automation_execution
  - entity_id: input_boolean.system_ready
  - condition: state
    state: 'off'
  mode: single
