Oh thanks. Didn’t realize so many of the sensors were disabled.
So now I (think) I have everything done, all panels are showing up in lovelace, but I am just seemingly unable to set the PIN codes via the UI. input_booleans, binary_sensor, automations, and scripts have been added… I have two PIN codes set in UI but neither are working, even with toggling off/on and with restarts. I do have one error/warning in logs:
Log Details (WARNING)
Logger: homeassistant.components.ozw.sensor
Source: components/ozw/sensor.py:40
Integration: OpenZWave (beta) (documentation, issues)
First occurred: 10:15:51 PM (1 occurrences)
Last logged: 10:15:51 PM
Sensor not implemented for value User Code
input_boolean:
allow_automation_execution:
name: 'Allow Automation'
initial: off
I played with this for most of the day yesterday including excluding/including, regenerating the lock-manager folder in packages… and couldn’t get this working. Seems like everything is good to go, except it doesn’t allow me to actually set PINs… so I guess it’s not good to go.
Found another error:
Logger: homeassistant.components.template.sensor
Source: components/template/sensor.py:248
Integration: template (documentation, issues)
First occurred: 6:58:56 PM (1 occurrences)
Last logged: 6:58:56 PM
Could not render template backdoor Status Report: str: Invalid domain name 'UC'
input_boolean.allow_automation_execution state is set to on.
I’ve toggled enabled in the GUI (off/on) and nothing so far. Haven’t actually been able to have the PIN codes stick. Any other ideas you think I could try? I’m using a Schlage BE469ZP deadbolt.
Huh. So yes, manually running the service does work. Just not in the UI… Interesting.
Update! Finally got this working. Not sure if it was automations.yaml or binary_sensor.yaml, but I did a bit of messing around and was able to figure out what the problem was. Can’t wait to add my front and side door locks too! Thanks for your help @firstof9
Also having a hard time getting codes sent to the lock. I did have it working using old yaml files posted back in May on this thread, but it has stopped working. Can you post your automation.yaml , binary_sensor.yaml, and config.yaml files to help compare?
Thanks for the files. I have tried every combination but just cant get it to work again. I will try OpenZwave as people are having more luck with that. Thanks again.
I cant seem to give up… this project keeps drawing me back to make it work. I noticed my setup stopped working when HACS updated lock-manager to 0.0.10 or 0.0.11. I just went into some logs and found the new code contains ozw instead of zwave.
Ah right, those files only work for ozwave. I switched to ozwave before I started messing with lock manager, so I can’t help you with the regular zwave integration. Sorry
Guys, sorry for the radio silence. I’ve been trying to fix some issues. Certain things aren’t working as expected, like numbered opening counts. We hope to have things settled down in the next week.
Thanks for reporting and updating firstof9 and Future Tense.
I uninstalled the ingratiation, HACS lock-manager, and deleted all files in packages. Reinstalled, added to Lovelace but still getting same error. Also getting this error:
Its stating scipt.py, and core.py files. That’s a little too deep for me to understand.
I’m sure if I do a fresh HA install it would probably clear, but trying to avoid that as much as possible. Do you think i should just go OpenZWave for future compatibility?
