Glad I could help.
That specific issue is addressed earlier in this thread.
Glad I could help.
I spent a bit of time getting this running and appear to have tripped at the finish line. (I think it might be a good idea to update the docs/readme/1st post now that the HACS install is recommended! I started backwards)
Lovelace is generated just fine, but codes I input arenāt being sent to the lock. The system_ready
binary sensor is turned off and wonāt come on. Automations are also turned off and turning them on manually donāt seem to do anything. Setting codes manually using ozw.set_usercode works fine.
initial: off
?Furthermore, I get the same Could not render template frontdoor Status Report: str: Invalid domain name 'UC'
others have reported here. I have read back over the last several weeks of troubleshooting, but Iāll hold on that problem for now - Iād like to get the codes working first!
ps Hi @firstof9 I got my Zwave network working again finally! Required a complete rebuild of my system but it was a good excuse to move to the new ozw beta.
The templates are getting a re-work as well as the Readme.
@joe_blow again I do thank you for the help and also @firstof9 and @ptdalen. I would have never received this much help as I have here in the ST community. Iām glad I made the switch to HA!
Thanks for your reply. Great to see the readme is being updated!
Do you happen to know of any potential troubleshooting steps to my problem with the lock not receiving codes and system_ready
never turning on?
Itās also highly likely Iām missing an obvious step to get things running fully.
if allow_automations
isnāt turning on thatāll block codes from being sent to your lock.
0.115 should fix the weirdness with the User Code
sensor now.
For those of you that were as confused as I was, the repository to install in HACS is here: https://github.com/FutureTense/lock-manager
You add the repository above via custom repositories, then click Install this Repository in HACS. Then you can either install the latest version or toggle to beta versions if you want to install the OpenZwave version.
It sounds simple now and maybe someone already covered all of this but it was hard to piece together in a 750 comment thread.
I should also add to that - if you install via HACS and youāre running the newer OZW Beta, you need to select that version of the install. After you do so, you need to change the automations and scrips youāre using a bit. Those are all set up for the older zwave implementation. Presumably all of this will be captured in the readme once the forthcoming template sensor fix is finished.
I released a new update for those running ozw. Support for zwave is slowing down, but we wonāt abandon it completely. There are a few issues with ozw, but for the most part it seems to be stable.
New as of 0.115, you can use input_datetime
directly in automations, this could slim down some of the time based automation bits.
Just updated to the new v-0.0.112-ozw and generated the new files. Looks like there are a few lines in the lock_manager_common.txt file that arenāt automatically generated.
Lines 333-363 sensor info is static, entity id listed as binary_sensor.zd2105us_5_recessed_door_window_sensor_access_control_door_window_open
for instance.
Also lines 174-180 (as well as line 377 and 450) has static lock.be469zp_connect_smart_deadbolt_locked
listed for the locknames.
These had to be manually changed to my entity ids to function.
Also seem to be getting these errors in logs for my locks now.
Template sensor 'backdoor_ac_last_changed' has no entity ids configured to track nor were we able to extract the entities to track from the value template(s). This entity will only be able to be updated manually
Template sensor 'backdoor_uc_last_changed' has no entity ids configured to track nor were we able to extract the entities to track from the value template(s). This entity will only be able to be updated manually
Does anyone have a good walk-through on how to install ozw? I tried https://www.home-assistant.io/integrations/ozw/ and could never be sure it was working correctly. I had MQTT installed through supervisor, then openzwave, then integrations. I was able to add devices, but never get the ozw integration to connect and explore the menus.
I saw there is a way of making a MQTT docker, but no clear instructions.
Yes there is.
Thatās awesome firstof9. Exactly what I was looking for. Thanks again.
You installed via HACS, correct? More to the point, did you open the integration and set your sensors from there?
After you close that, you should restart HA.
Yes. installed via HACS. Iām saying the actual lock_manager_common.txt
file in custom_components/lock-manager doesnāt have the actual automatically generated variables listed.
- alias: CASE_LOCK_NAME Locked state changed
platform: state
entity_id: lock.be469zp_connect_smart_deadbolt_locked
condition:
- condition: state
entity_id: 'binary_sensor.allow_automation'
state: 'on'
- condition: template
value_template: >-
{% set report = states.input_text.LOCKNAME_status_report.state %}
{% set a = report.split(';') %}
{% set lockcmd = states.input_number.LOCKNAME_lock_command.state %}
{% set lockuser = states.input_number.LOCKNAME_lock_user.state %}
{% set lockcmd = a[0] %}
{% set lockuser = a[2] %}
{% set lockstate = states.lock.be469zp_connect_smart_deadbolt_locked.state %}
{% if (lockstate=='locked') %}
{% set lockval=5 %}
{% else %}
{% set lockval=6 %}
{% endif %}
{{ ((lockcmd | int) != (lockval | int)) and (lockuser | int ==0)}}
- service: input_number.set_value
data_template:
entity_id: input_number.LOCKNAME_lock_command
value: >-
{{ 66 }}
{% else %}
{{ 77 }}
{% endif %}
Here is a snippet from lines 147-180. See how lock.be469zp_connect_smart_deadbolt_locked
is filled for some of the states and entities rather than LOCKNAME variable?
It shouldnāt have any generated entities. You did find a bug, as I hardcoded some stuff in there. Iāll try and fix it in a bit.
LOL, sorry I should have just said that it was a bug from the start The correct generated entities donāt show up in the lock_manager_common.yaml file. Just letting you know!
