Make sure to report bugs on the github way easier to track than on the forum.
Did you find a solution to this? I have the same lock and also am not showing a user code sensor.
The Schlage lock? Are you using the integration? The lock should appear in the drop down.
Yes I am using the integration and when I get the the point of configuration, I donāt have a user code sensor to select. Same issue as described above by user tvo. I also tried to zwave exclude and re-include the lock and have the same exact entities.
Here is my entity list for the lock:
Iāve got most of this working but struggling with notifications. There is an error in my log Could not render template kahudoor Status Report: str: Invalid domain name āUCā
In my common.yaml file Iāve got
value_template: >
{% set UC = 'sensor.schlage_allegion_be469_touchscreen_deadbolt_alarm_level_kahudoor' %}
{% set AC = 'sensor.schlage_allegion_be469_touchscreen_deadbolt_access_control_kahudoor' %}
{% if (((as_timestamp(now()) - as_timestamp(states.UC.last_changed)) < 15) and ((as_timestamp(now()) - as_timestamp(states.AC.last_changed)) < 15)) %}
{% set usercode_value = states(UC) %}
{% set alarm_type_value = states(AC) %}
any ideasā¦?
Iām not sure how youāre pulling those entities up, but are you sure thereās not another āpageā set of results?
I say this because I too, even as the developer (along with @firstof9) have had issues with all lock entities not appearing. It took a lot of headaches to resolve this. I ended up bricking my lock in the process and had to buy a new one. What finally worked was getting a new USB Zwave stick.
I donāt know how many zwave devices are part of your network, but if you can stomach having to rebuild your zwave network (perhaps using the backup/restore utility) I suggest you remove all zwave devices from your HA network and then factory reset your USB z-wave stick using a paper clip. I had already spent so much time and money on my bricked lock that another $50 for a new stick didnāt phase me.
If you do start with a new z-wave network, make sure you keep things simple at first. Only add the lock and door sensors, if any.
Are you using zwave or ozw?
zwave. Tried with firstof9ās automated install and ended up with that error. Just started from scratch compiling the newest one from your repo and have ended up with the same error
Have also noticed the Status Report service is unavailable and canāt be started
Are you using v0.0.13-ozw? From the integration increase the number of Code slots
by one, click submit. Then check the packages directory to see if your new value for code slots has a matching number of files, e.g. frontdoor_lock_manager_5.yaml
If not, your files arenāt being generated properly and you should first restart Home Assistant (or even reboot your machine running it)
Iāve just copied the Master zip. Is that incorrect? Could use the v13 ozw one but am not using the OpenZWave integration
Donāt have an integration to add one slot and press submitā¦
Install via HACS. Thereās instructions somewhere in this thread.
okay yeah Iāve done that now. Added a 9th code slot, rebooted. It added. However now I have a binary_sensor.active_mydoor1 error on every slot, and on the newly added slot entity not available for all the inputs as well
Anytime you make a change via the GUI integration and click submit, you need to restart home assistant to load the changes. You should post a screenshot of your GUI inputs as well as the errors youāre getting. We canāt really help you if you just say youāre getting āan errorā.
So Iāve gone full circle now back to the Invalid Domain Name (āUCā) error
Sorry I just needed a full restart before as you said for the other entity id errors.
Now using v11 to avoid the ozw/set_usercode errors. But also tried v13 and manually changing those ozw/set_usercode lines to the v11 version, also tried master. Keep getting this error.
Maybe worth noting as well on the set UC line mine is sensor.lock.alarm_level but saw on a post earlier from firstof9 his was lock.user_code but I donāt have that sensor
also just noting everything else seems to work, I can set user codes and unlock/lock the door
Error 1
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 306, in async_render_to_info
render_info._result = self.async_render(variables, **kwargs)
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 285, in async_render
return compiled.render(kwargs).strip()
File "/usr/local/lib/python3.8/site-packages/jinja2/environment.py", line 1090, in render
self.environment.handle_exception()
File "/usr/local/lib/python3.8/site-packages/jinja2/environment.py", line 832, in handle_exception
reraise(*rewrite_traceback_stack(source=source))
File "/usr/local/lib/python3.8/site-packages/jinja2/_compat.py", line 28, in reraise
raise value.with_traceback(tb)
File "<template>", line 2, in top-level template code
File "/usr/local/lib/python3.8/site-packages/jinja2/sandbox.py", line 407, in getattr
value = getattr(obj, attribute)
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 415, in __getattr__
raise TemplateError(f"Invalid domain name '{name}'")
homeassistant.exceptions.TemplateError: str: Invalid domain name 'UC'
Please donāt mix and match code manually. Use v13ozw apply the integration and reboot. Then report your errors. If youāre using ozw, then use an ozw version. Donāt use master. At all.
You are seeing different sensors than @firstof9 because he has a different lock. Heās using a Kiwkset and you have a Schlage. As a Schlage user you should see something like this:
You can see the selected sensor is a āuser_codeā and the one below is an āaccess_controlā. If you arenāt seeing those, then youāre lock has not been added properly to your zwave network.
Wait, earlier you said you were using OpenZWave? Did you change at some point?
I was using the integrated zwave 1.4
Never got a user_code sensor so I tried re-pairing the lock, no dice.
Have now switched to the OpenZWave beta and v13ozw and I do now have a user_code sensor. Havenāt quite finished setting it all up but hopefully this works
okay so being on the newest version and using OpenZWave is working. No errors now, also no notifications yet but weāll get there, havenāt really had a crack at that yet
thanks for the help!
Nice job. I hope they release ozw ā and soon. I donāt want to go back to supporting two versions.
No, I have not been successful in getting additional user code entities. I havenāt tried the more drastic measures yet, either.
