KeyMaster Z-Wave lock manager and scheduler
If you have a Schlage, you should get access_control and user_code entries. In the ozw integration they may be hidden under disabled entities.
For example, mine show up as:
  • sensor.be469zp_connect_smart_deadbolt_user_code
  • sensor.be469zp_connect_smart_deadbolt_access_control
But under disabled entities I also see
  • sensor.schlage_connect_smart_deadbolt_user_code
Notice the 2nd one is missing the be469zp “header”? Enabling that and refreshing the lock might make that appear “enabled”.
I have 3 Schlage BE469ZP. They all have:
sensor.be469zp_connect_smart_deadbolt_alarm_level
And they display in the Entities list as “Schlage Connect Smart Deadbolt: User Code”.
The lock-manager package is working for me, using this entity for user codes, under ozw.
There is also a disabled entity named user_code, but I enabled it a few days ago and it doesn’t seem to update/display any info even after a node refresh. Alarm Level works for my usercodes however.
Odd that the entities are different.
What does the user_code entity look like?
sensor.be469zp_connect_smart_deadbolt_user_code_frontdoor
It WAS schlage_connect until I read your note about schlage/be469zp. I renamed it this morning. It still isn’t showing any data.
Edit: But like I said, lock-manager working fine using alarm_level as the user code sensor.
Renaming it won’t make a difference. I’ve been recommending people to exclude/include their locks and just use what HA assigns it for a name. If you have multiple locks, add a simple prefix in front of all the entities.
If you open up ozw, how many entities are disabled? Is user_code in there?
The only disabled entity is that user code. All other entities are fine. I’m not sure how to list all the entities in ozw but I think this is what you might mean:
See the two user codes entries. The one with no data is the now-enabled user_code entity.
As I said, alarm_level is working just fine to report the correct user code with lock-manager.
Ok, instead try looking at the OpenZWave integration and open up the Schlage device. How many disabled entities are there?
Do both of these appear as entities, either enabled or disabled?
The only one that was ever showing as disabled was the _user_code entity (which I enabled this morning). All others have always been enabled/working.
Edit: The second entity, Front Door User Code Test, is the _user_code entity I just re-enabled.
There are two user_code entries. That’s why I’m asking you to put the full name
sensor.be469zp_connect_smart_deadbolt_alarm_level - working user code entity
sensor.be469zp_connect_smart_deadbolt_user_code - blank, previously disabled, non-working entity.
Do you have discord? We should really hash this out over there on #zwave
@FutureTense are you using the sensor.be469zp_connect_smart_deadbolt_user_code or the sensor.schlage_connect_smart_deadbolt_user_code entity for user_code?
The be469 sensor. No idea what the other one is for.
Thanks. I just saw it recently in my disabled entities list too. It doesn’t seem to have any values associated with it. :woman_shrugging:
Between the install instructions at the top of this thread and the one on git install is a bit confusing. Is there a file list of the files to put in /packages/lock-manager/? When I try to install I keep getting a log error “Package services setup failed. Component generate_package Integration ‘generate_package’ not found”.
I have Home Assistant installed on Windows in virtual box. How would I install this? I apologize but I am very new to Home assistant and virtual machines. Any help you could give me is greatly appreciated.
Install via HACS.
@firstof9 I don’t see lock manager in HACS. Am I missing something?
Add the custom repo https://github.com/FutureTense/lock-manager
Just pushed a new README for ozw. It’s a very rough draft and certainly full of errors. But better than before.
