If you have battery powered nodes they may not have checked in yet. You can try waking them up or just let them check in on their own (note this excludes locks they’re a special battery node).
I have a bunch of these warnings gunking up my log:
sensor_cleanup_keypad_10: Already running
[time] - Automation (WARNING)
I have one for each 1-10. Is that supposed to happen?
Yup that’s the automation firing off.
Thanks! How can I suppress those? I tried this and it didn’t work:
logger:
default: info
logs:
homeassistant.integrations.lock_manager: error
Got it, I just checked the details on the log and it included homeassistant.components.automation so I used that instead.
this worked a treat thank you! I was so scared I was going to have to reprogram all my devices! I think I got everything in open zwave and working all stuff renamed in automations and them all working dashboards etc Im kinda tired though now so tomorrow Ill read the open zwave parts of the instructions and see if we can get the lock manager going. as for devices that weren’t showing up its one secure included door contact and a couple secure included smoke detectors that maybe just haven’t checked on yet… Weird just the secure stuff didn’t transfer except the lock which transferred fine…
They’re there but they’re battery devices so you have to either wake them up per the manual’s instructions (yes RTFM) or wait for them to wake up on their own.
Okay came back to it after eating dinner. With being switched over open zwave I went and reinstalled lock code manager in hacs, rebooted, enabled disabled entities in my lock, installed the integration, added the lovelace card, did the easy additional steps for ozw, and rebooted. I’m happy to report the lock manager is up and running and functioning perfectly now! Thanks for all your help I most definitely owe you a beer @firstof9
I just have a bunch of custom arduino type devices that all communicate with my old mosquitto server I had long before I got into home assistant.
You should look into the ESPHome project. If you are already running containers it’s fairly easy to get up and running. You can convert your arduino code to work with ESPHome without too much trouble. Just follow the examples for the use case that matches your functionality. And as a huge win, you can take advantage of OTA updates. No more pulling USB cables and messing with the annoying arduino editor. Once you get one OTA update running, you can hack your firmware without getting off your ass.
Yeah I have esp home on a couple devices it’s pretty awesome way to get a straight forward sensor into home assistant but I have a bunch of projects for instance one example is I’ve made to control my pool. Fill Level detection, temperature, ph, orp, acid injection, chlorine injection, pump speed control, return valve actuators, and water valves. A little bit much customization wise to program with esp home I’d think so I just wrote the code haha plus it was before esp home existed that I made it and it works. I just added Mqtt to it to make it talk to home assistant too. That’s just one example of custom inventions I’ve got around the house i made lol that said a lot of my devices are particle photon based so I can OTA firmware those from anywhere with a browser and internet connection. I also enabled ota on a lot of my node mcu or wemos d1 mini devices. It’s not bad to upgrade the firmware ota using the arduino ide either. I’m just glad I didn’t have to change the firmware on all those devices even if it was ota lol much easier to set up that Mqtt forwarding in the config of my existing mosquitto config haha.
For BE469 w/ OZW
I am not sure what exactly did it, but I removed the integration, deleted all of the helpers, and updated openzwave to the latest. When I re-added the integration, everything seems to now be working as it should. The log is showing that it is “Utilizing BE469 work around code.” Thanks for all the work on this.
I think the instructions might need to be updated. When I added the mqtt binary sensor I received an error because I was missing the off_delay parameter even though the MQTT documentation says that is optional. So I added it and set it to zero to make it effectively do nothing as far as I can tell.
I’m sorry for such a long delay. I’ve tested your latest package with both my be469 and my fe599, and want to report that they both work great!! I found one issue that I could not figure out. Nothing directly to do with your packages, but my allow automation would never turn on. I kept looking at it and realized this was happening.
Restart HA - It would be off as expected
Home assistant start I’d see the input boolean turn on and immediately turn off. I watched it through several reboots, always on and then immediatly off. Maybe others dont have this problem, not sure. Was weird because system ready would not have this behavior.
Anyway I added this condition to the recommended automation, and I’m working now!!
- alias: HA Automations Homeassistant start-up
initial_state: true
platform: homeassistant
event: start
condition:
- condition: not
conditions:
- condition: state
entity_id: binary_sensor.ozw_network_status
state: "on"
- service: input_boolean.turn_off
entity_id: input_boolean.system_ready
entity_id: 'input_boolean.allow_automation_execution'
do you see any issues with this added condition??
I believe that has been my issue quite often during testing in the past. Anyway as stated in the begining. For me with the old legacy b469 and fe599 (not zwave plus), Everything seems to be working. Will test more later to verify the scheduleing,and lock counts but I’m sure they’ll work fine.
If I had one “feature request” it would be to sync codes across multiple locks. That was one of the things keeping me on my package vs yours, but this has surpassed mine with the latest features, I can hack other ways to “sync across locks” if I want.
Thanks for your hard work!!! this is great!
You’re in luck, @FutureTense is working on that already
So the original code:
- alias: open_zwave_network_up
initial_state: true
- platform: homeassistant
event: start
- platform: state
to: "on"
condition:
- condition: state
state: "on"
- service: homeassistant.turn_on
entity_id: input_boolean.allow_automation_execution
Triggers on HA startup OR the binary_sensor
switching to “on”, as long as the binary_sensor
has the state of “on”. This is supposed to guard against the network being down at HA start up for some reason and I’ve personally never experienced issues with it.
This of course means you have to have included the binary_sensor
template as well:
binary_sensor:
- platform: mqtt
state_topic: OpenZWave/1/status/
value_template: >
{{ "ON" if value_json.Status in ["driverAwakeNodesQueried", "driverAllNodesQueriedSomeDead", "driverAllNodesQueried"] else "OFF" }}
json_attributes_topic: OpenZWave/1/status/
device_class: "connectivity"
My issue seemed to be the turning off of input booleans with this
- alias: homeassistant start-up
initial_state: true
event: start
also triggering was
initial_state: true
event: start
- platform: state
to: "on"
condition:
- condition: state
state: "on"
I think they were both running. Do I still need both? Adding the condition solved the issue, and sync across locks is AWESOME!!
Hi All. First time post here and relatively new user moving over from Smartthings and Webcore. I followed the instructions in the README on git and got through most of it. A missing piece I picked up from the previous posts was a need to add to my configuration.yaml:
homeassistant:
packages: !include_dir_merge_named packages
Unfortunately a config check with packages feature turned on throws a bunch of errors:
config $ ha core check
Processing... Done.
Error: Testing configuration at /config
Failed config
homeassistant:
- expected a dictionary for dictionary value @ data['packages']['automation']
- packages: [source /config/configuration.yaml:1]
automation: [source /config/packages/lock-manager/frontdoor/frontdoor_lock_manager_common.yaml:129]
- action: [source /config/packages/lock-manager/frontdoor/frontdoor_lock_manager_common.yaml:140]
- service: script.frontdoor_refreshnodeinfo
Any thoughts or pointers? I’m having trouble as a newbie deciphering the error message.
Thanks!
No just the ozwave network up automation will do.
Post your configuration.yaml
and redact any personal info like usernames and passwords.
Here is my configuration.yaml:
#homeassistant:
# packages: !include_dir_merge_named packages
logger:
default: info
logs:
homeassistant.components: info
frontend:
themes: !include_dir_merge_named themes
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
# Text to speech
tts:
- platform: google_translate
input_boolean:
allow_automation_execution:
name: 'Allow Automation'
initial: off
system_ready:
initial: off
group: !include groups.yaml
script: !include scripts.yaml
scene: !include scenes.yaml
binary_sensor:
sensors:
allow_automation:
friendly_name: "Allow Automation"
value_template: "{{ is_state('input_boolean.allow_automation_execution', 'on') }}"
sensors:
system_ready:
friendly_name: "System ready"
value_template: "{{ is_state('input_boolean.system_ready', 'on') }}"
device_class: moving
sensors:
occupancy_mf_ki_fr:
friendly_name: 'Kitchen & Family Room Occupancy'
value_template: >-
{% if is_state("sensor.mf_ki_ls_burglar",'0') or is_state("sensor.mf_ki_ls_burglar",'254') %}
{% if is_state("sensor.mf_ki_ls_island_burglar",'0') or is_state("sensor.mf_ki_ls_island_burglar",'254') %}
{% if is_state("sensor.mf_ki_ls_table_burglar",'0') or is_state("sensor.mf_ki_ls_table_burglar",'254') %}
{% if is_state("sensor.mf_fr_ls_burglar",'0') or is_state("sensor.mf_fr_ls_burglar",'254') %}
{% if is_state("sensor.mf_fr_ls_outlet_burglar",'0') or is_state("sensor.mf_fr_ls_outlet_burglar",'254') %}
False
{% else %}
True
{% endif %}
{% else %}
True
{% endif %}
{% else %}
True
{% endif %}
{% else %}
True
{% endif %}
{% else %}
True
{% endif %}
sensors:
occupancy_mf_lr_dr:
friendly_name: 'Living & Dining Room Occupancy'
value_template: >-
{% if is_state("sensor.mf_dr_ls_dummy_burglar",'0') or is_state("sensor.mf_dr_ls_dummy_burglar",'254') %}
{% if is_state("sensor.mf_dr_ls_burglar",'0') or is_state("sensor.mf_dr_ls_burglar",'254') %}
{% if is_state("sensor.mf_lr_ls_burglar",'0') or is_state("sensor.mf_lr_ls_burglar",'254') %}
False
{% else %}
True
{% endif %}
{% else %}
True
{% endif %}
{% else %}
True
{% endif %}
sensors:
occupancy_ba_sa:
friendly_name: 'Basement Storage Area Occupancy'
value_template: >-
{% if is_state("sensor.ba_sa_ls_burglar",'0') or is_state("sensor.ba_sa_ls_burglar",'254') %}
{% if is_state("sensor.ba_sa_ls_furnace_burglar",'0') or is_state("sensor.ba_sa_ls_furnace_burglar",'254') %}
False
{% else %}
True
{% endif %}
{% else %}
True
{% endif %}
sensors:
occupancy_2f_mb:
friendly_name: 'Master Bedroom Occupancy'
value_template: >-
{% if is_state("sensor.2f_mb_ls_desk_burglar",'0') or is_state("sensor.2f_mb_ls_desk_burglar",'254') %}
{% if is_state("sensor.2f_mb_ms_desk_burglar",'0') %}
False
{% else %}
True
{% endif %}
{% else %}
True
{% endif %}
sensors:
occupancy_ba_st:
friendly_name: 'Basement Stairs Occupancy'
value_template: >-
{% if is_state("sensor.ba_st_ls_burglar",'0') or is_state("sensor.ba_st_ls_burglar",'254') %}
{% if is_state("sensor.ba_oa_ls_burglar",'0') or is_state("sensor.ba_oa_ls_burglar",'254') %}
False
{% else %}
True
{% endif %}
{% else %}
True
{% endif %}
sensors:
occupancy_ex_fd:
friendly_name: 'Front Door Occupancy'
value_template: >-
{% if is_state("sensor.ex_fd_ms_burglar",'0') %}
False
{% else %}
True
{% endif %}
sensors:
occupancy_mf_mr_hw:
friendly_name: 'Mud Room and Hallway Occupancy'
value_template: >-
{% if is_state("sensor.mf_ga_ls_burglar",'0') or is_state("sensor.mf_ga_ls_burglar",'254') %}
{% if is_state("sensor.mf_mr_ls_buglar",'0') or is_state("sensor.mf_mr_ls_burglar",'254') %}
{% if is_state("sensor.mf_mr_dummy_ls_buglar",'0') or is_state("sensor.mf_mr_dummy_ls_burglar",'254') %}
False
{% else %}
True
{% endif %}
{% else %}
True
{% endif %}
{% else %}
True
{% endif %}
sensors:
occupancy_mf_mr:
friendly_name: 'Mud Room Occupancy'
value_template: >-
False
{% else %}
True
{% endif %}
{% else %}
True
{% endif %}
sensors:
occupancy_mf_ef:
friendly_name: 'Entry Way Occupancy'
value_template: >-
{% if is_state("sensor.ex_fd_ls_burglar",'0') or is_state("sensor.ex_fd_ls_burglar",'254') %}
{% if is_state("sensor.ex_dw_ls_buglar",'0') or is_state("sensor.ex_dw_ls_burglar",'254') %}
{% if is_state("sensor.2f_hw_ls_buglar",'0') or is_state("sensor.2f_hw_ls_burglar",'254') %}
{% if is_state("sensor.mf_ew_ls_buglar",'0') or is_state("sensor.mf_ew_ls_burglar",'254') %}
False
{% else %}
True
{% endif %}
{% else %}
True
{% endif %}
{% else %}
True
{% endif %}
{% else %}
True
{% endif %}
sensors:
occupancy_ba_oa:
friendly_name: 'Basement Open Area Occupancy'
value_template: >-
False
{% else %}
True
{% endif %}
sensors:
occupancy_mf_rr:
friendly_name: 'Reading Room Occupancy'
value_template: >-
{% if is_state("sensor.mf_rr_ls_burglar",'0') or is_state("sensor.mf_rr_ls_burglar",'254') %}
False
{% else %}
True
{% endif %}
# Webserver
http:
server_port: 80
And here is scripts.yaml:
# feel free to add post startup calls here
system_startup_cleanup:
sequence:
- condition: state
entity_id: 'input_boolean.system_ready'
state: 'off'
# - service: homekit.start
Your config’s a mess…
homeassistant:
packages: !include_dir_named packages
# Webserver
http:
server_port: 80
logger:
default: info
logs:
frontend:
default_config:
# Text to speech
tts:
input_boolean:
initial: off
system_ready:
initial: off
binary_sensor:
sensors:
allow_automation:
system_ready:
occupancy_mf_ki_fr:
value_template: >-
False
{% else %}
True
{% endif %}
{% else %}
True
{% endif %}
{% else %}
True
{% endif %}
{% else %}
True
{% endif %}
{% else %}
True
{% endif %}
occupancy_mf_lr_dr:
value_template: >-
False
{% else %}
True
{% endif %}
{% else %}
True
{% endif %}
{% else %}
True
{% endif %}
occupancy_ba_sa:
value_template: >-
False
{% else %}
True
{% endif %}
{% else %}
True
{% endif %}
occupancy_2f_mb:
value_template: >-
False
{% else %}
True
{% endif %}
{% else %}
True
{% endif %}
occupancy_ba_st:
value_template: >-
False
{% else %}
True
{% endif %}
{% else %}
True
{% endif %}
occupancy_ex_fd:
value_template: >-
False
{% else %}
True
{% endif %}
occupancy_mf_mr_hw:
value_template: >-
False
{% else %}
True
{% endif %}
{% else %}
True
{% endif %}
{% else %}
True
{% endif %}
occupancy_mf_mr:
value_template: >-
False
{% else %}
True
{% endif %}
{% else %}
True
{% endif %}
occupancy_mf_ef:
value_template: >-
False
{% else %}
True
{% endif %}
{% else %}
True
{% endif %}
{% else %}
True
{% endif %}
{% else %}
True
{% endif %}
occupancy_ba_oa:
value_template: >-
False
{% else %}
True
{% endif %}
occupancy_mf_rr:
value_template: >-
False
{% else %}
True
{% endif %}
also you don’t need the script stuff.
Yeah. Still learning the lay of the land and hacking up config as I go. Thanks for taking a look and cleaning up! I gave your mods a try and I’m still getting the same error.
Processing... Done.
Failed config
homeassistant:
alias: frontdoor_refresh_lock_node_finished
condition: [source /config/packages/lock-manager/frontdoor/frontdoor_lock_manager_common.yaml:136]
- condition: state
Here is the frontdoor_lock_manager_common.yaml generated by Lock-Manager:
## WARNING ##
# This file is auotmaticly generated, any changes
# will be overwritten.
################ COMMON ENTITIES ###############
############ timer: #####################
timer:
frontdoor_refresh_lock_node:
duration: '00:15:00'
############### input_text: #################
input_text:
frontdoor_status_report:
name: frontdoor Status report
############### input_number: #################
input_number:
frontdoor_lock_command:
name: frontdoor Lock command
min: 0
max: 999
frontdoor_lock_user:
name: frontdoor Lock user
min: 0
max: 999
############### input_boolean: #################
input_boolean:
frontdoor_lock_notifications:
name: frontdoor Lock Notifications
frontdoor_dooraccess_notifications:
name: frontdoor Door Notifications
frontdoor_garageacess_notifications:
name: frontdoor Garage Notifications
frontdoor_reset_lock:
name: frontdoor reset lock
################### sensor: ####################
- platform: time_date
display_options:
- "time"
- "date"
- "date_time"
- "date_time_iso"
- "time_date"
- "time_utc"
- "beat"
sensors:
frontdoor_ac_last_changed:
friendly_name: frontdoor AC Last Changed From Present
unit_of_measurement: "seconds"
value_template: >-
{% set CONTROL = 'input_number.frontdoor_lock_command' %}
{% set CONTROLlc = states.input_number[CONTROL.split('.')[-1]].last_changed %}
{{ (as_timestamp(now()) - as_timestamp(CONTROLlc)) | float }}
frontdoor_uc_last_changed:
friendly_name: frontdoor UC Last Changed From Present
value_template: >-
{% set CONTROL = 'input_number.frontdoor_lock_user' %}
################### script : ####################
script:
sequence:
- service: script.frontdoor_manual_notify
data_template:
title: "reset"
message: "frontdoor"
frontdoor_conditional_notify:
sequence:
- condition: template
value_template: >-
{% set inputbool = boolean %}
{% if states(inputbool) == 'on'%}
true
{% else %}
false
{% endif %}
data_template:
title: "{{title}}"
message: "{{message}}"
frontdoor_refreshnodeinfo:
description: 'Send MQTT RefreshNodeInfo command'
sequence:
- service: system_log.write
data_template:
message: "frontdoor_TEMPLATENUM started noderefreshinfo: {{ now() }}"
level: debug
- service: mqtt.publish
topic: 'OpenZWave/1/command/refreshnodeinfo/'
payload: >-
{% set node_id = state_attr('lock.mf_ew_dl_locked_frontdoor','node_id') %}
{ "node": {{ node_id }} }
retain: true
frontdoor_refresh_codes:
description: 'Refreshes lock user codes'
sequence:
data_template:
message: "refresh user codes: {{ now() }}"
level: debug
# - service: mqtt.publish
# data:
# topic: 'OpenZWave/1/command/refreshnodeinfo/'
# payload: >-
# {% set node_id = state_attr('lock.mf_ew_dl_locked_frontdoor','node_id') %}
# { "node": {{ node_id }} }
# retain: true
################### automation: ####################
automation:
- alias: frontdoor_refresh_lock_node_finished
platform: event
event_type: timer.finished
event_data:
entity_id: timer.frontdoor_refresh_lock_node
condition:
- condition: state
entity_id: "binary_sensor.allow_automation"
state: "on"
- alias: frontdoor Lock Command
platform: state
entity_id: sensor.mf_ew_dl_access_control_frontdoor
condition:
- condition: state
state: "on"
- service: input_number.set_value
data_template:
entity_id: input_number.frontdoor_lock_command
value: >-
{{ states('sensor.mf_ew_dl_access_control_frontdoor') | int}}
- alias: frontdoor User Command
platform: state
entity_id: sensor.mf_ew_dl_alarm_level_frontdoor
condition:
- condition: state
state: "on"
data_template:
entity_id: input_number.frontdoor_lock_user
value: >-
{{ states.sensor.mf_ew_dl_alarm_level_frontdoor.state | int}}
- alias: frontdoor RF Locked State Changed
platform: state
entity_id: lock.mf_ew_dl_locked_frontdoor
condition:
- condition: state
state: "on"
value_template: >-
{% set lockuser = states.sensor.mf_ew_dl_alarm_level_frontdoor.state | int %}
{% set lockcmd = states.sensor.mf_ew_dl_access_control_frontdoor.state | int %}
{% set timediff = (as_timestamp(now()) - as_timestamp(states.sensor.mf_ew_dl_access_control_frontdoor.last_changed)) | float %}
{{ lockuser | int == 0 and timediff > 2 }}
data_template:
value: >-
{% set lockstate = states.lock.mf_ew_dl_locked_frontdoor.state %}
{% if (lockstate == 'locked') %}
66
{% elif (lockstate == 'unlocked') %}
67
{% else %}
{{ lockcmd | int}}
{% endif %}
# {% set doordiff = as_timestamp(now()) - as_timestamp(states.lock.be666zp_connect_smart_deadbolt_locked.last_changed) %}
# {% set contdiff = as_timestamp(now()) - as_timestamp(states.sensor.be666zp_connect_smart_deadbolt_access_control.last_changed) %}
# {% set atv = 24 if (doordiff) < 15 and (contdiff) > 15 and (states.lock.be666zp_connect_smart_deadbolt_locked.state) == 'locked' else alarm_type_value %}
# {% set atv = 25 if (doordiff) < 15 and (contdiff) > 15 and (states.lock.be666zp_connect_smart_deadbolt_locked.state) == 'unlocked' else alarm_type_value %}
- alias: frontdoor Status Report
platform: state
entity_id: input_number.frontdoor_lock_command, input_number.frontdoor_lock_user
condition:
- condition: state
state: "on"
value_template: "{{ states('sensor.mf_ew_dl_access_control_frontdoor') != 0 }}"
- service: input_text.set_value
data_template:
entity_id: input_text.frontdoor_status_report
value: >-
{% set UC = 'sensor.mf_ew_dl_alarm_level_frontdoor' %}
{% set AC = 'sensor.mf_ew_dl_access_control_frontdoor' %}
{% set UClc = states.sensor[UC.split('.')[-1]].last_changed %}
{% set AClc = states.sensor[AC.split('.')[-1]].last_changed %}
{% set usercode_value = states.input_number.frontdoor_lock_user.state | int | string %}
{% set alarm_type_value = states.input_number.frontdoor_lock_command.state | int | string %}
{% set atv = 0 %}
{% if (alarm_type_value | int == 66 or alarm_type_value | int == 67) %}
{% if 'alarm_type' in AC %}
{% set atv = alarm_type_value | int - 42 %}
{% elif 'access_control' in AC %}
{% set atv = alarm_type_value | int - 63 %}
{% endif %}
{% endif %}
{% if atv != 0 %}
{% set alarm_type_value = atv %}
{% endif %}
{% set alarm_type_value = alarm_type_value | string %}
{% set alarm_type_general_actions = {
'999':'Kwikset',
'0':'No Status Reported',
'9':'Lock Jammed',
'17':'Keypad Lock Jammed',
'21':'Manual Lock',
'22':'Manual Unlock',
'23':'RF Lock Jammed',
'24':'RF Lock',
'25':'RF Unlock',
'26':'Auto Lock Jammed',
'27':'Auto Lock',
'32':'All Codes Deleted',
'161':'Bad Code Entered',
'167':'Battery Low',
'168':'Battery Critical',
'169':'Battery Too Low To Operate Lock' } %}
{% set alarm_type_lock_actions = {
'16':'Keypad Unlock',
'18':'Keypad Lock',
'19':'Keypad Unlock',
'162':'Lock Code Attempt Outside of Schedule' } %}
{% set alarm_type_code_actions = {
'33':'Code Deleted',
'112':'Code Changed',
'113':'Duplicate Code' } %}
'999':'Schlage',
'1':'Manual Lock',
'2':'Manual Unlock',
'3':'RF Lock',
'4':'RF Unlock',
'7':'Manual not fully locked',
'8':'RF not fully locked',
'9':'Auto Lock locked',
'10':'Auto Lock not fully locked',
'11':'Lock Jammed',
'16':'Keypad temporary disabled',
'17':'Keypad busy' } %}
'5':'Keypad Lock',
'6':'Keypad Unlock' } %}
'12':'All User Codes Deleted',
'13':'Single Code Deleted',
'14':'New User Code Added',
'18':'New Program Code Entered',
'15':'Duplicate Code' } %}
{% endif %}
{% if alarm_type_value in alarm_type_code_actions %}
{{alarm_type_value}};{{ alarm_type_code_actions[alarm_type_value] }};{{usercode_value}}
{% elif alarm_type_value in alarm_type_lock_actions %}
{{alarm_type_value}};{{ alarm_type_lock_actions[alarm_type_value] }};{{usercode_value}}
{% elif alarm_type_value in alarm_type_general_actions %}
{{alarm_type_value}};{{ alarm_type_general_actions[alarm_type_value] }};{{usercode_value}}
{% else %}
{{alarm_type_value}};{{alarm_type_value}}-Unknown Alarm Type Value;{{usercode_value}}
{% endif %}
- alias: frontdoor Lock Notifications
platform: state
condition:
- condition: state
state: "on"
value_template: >-
{% set report = states.input_text.frontdoor_status_report.state %}
{% set a = report.split(';') %}
{% if (a|length) != 3 or (a[2] == "0") %}
{{ true }}
{% else %}
{{ true }}
{% endif %}
- service: script.frontdoor_conditional_notify
data_template:
boolean: input_boolean.frontdoor_lock_notifications
title: frontdoor
message: >-
{{ a[1] }}
- alias: frontdoor User Notifications
platform: state
condition:
- condition: state
state: "on"
value_template: >-
{% if (a|length) == 3 and (a[2] | int > 0) %}
{{ true }}
{% else %}
{{ false }}
{% endif %}
value_template: >-
{% set entity_id = 'notify_frontdoor_' + a[2] %}
{% set notify = states['input_boolean'][entity_id].state %}
{{ notify == "on" }}
data_template:
title: >-
{{ a[1] }}
message: >-
{% set entity_id = 'input_text.frontdoor_name_' + a[2] %}
{% set user = states(entity_id) %}
{{ user }}
- alias: frontdoor Sensor Close
condition:
- condition: state
state: "on"
entity_id: binary_sensor.mf_ew_ds_sensor_frontdoor
platform: state
to: "off"
data_template:
boolean: input_boolean.frontdoor_dooraccess_notifications
title: frontdoor
message: "Closed"
- alias: frontdoor Sensor Opened
condition:
- condition: state
state: "on"
platform: state
to: "on"
data_template:
title: frontdoor
message: "Opened"
# - alias: frontdoor Add Code
# trigger:
# entity_id: binary_sensor.active_frontdoor_1
# platform: state
# to: "on"
# condition:
# - condition: state
# entity_id: "binary_sensor.allow_automation"
# state: "on"
# action:
# - choose:
# - conditions: >
# {{ True }}
# # this comment preserves formating
# sequence:
# - service: ozw.set_usercode
# data_template:
# entity_id: lock.mf_ew_dl_locked_frontdoor
# code_slot: >-
# {% set object_id = trigger.to_state.object_id %}
# {% set index = object_id.rfind('_') + 1 %}
# {% set code_slot = object_id[index:] %}
# {{ code_slot }}
# usercode: >-
# {% set codetext = 'frontdoor_pin_' + code_slot | string %}
# {% set code = states['input_text'][codetext].state %}
# {{ code | string }}
# - conditions: >
# {{ True == False }}
# sequence:
# - service: lock.set_usercode
# data_template:
# node_id: >-
# {{ state_attr('lock.mf_ew_dl_locked_frontdoor','node_id') }}
# code_slot: >-
# {{ code_slot }}
# usercode: >-
- alias: frontdoor Update Code
entity_id: input_text.frontdoor_pin_1
platform: state
condition:
- condition: state
state: "on"
value_template: >-
{% set b = 'input_boolean.enabled_frontdoor_' + code_slot | string %}
{{ is_state(b, 'on') and (trigger.from_state.state != trigger.to_state.state)}}
- service: persistent_notification.create
data_template:
title: frontdoor LOCK MANAGER
message: >-
{{ 'You changed the PIN for code ' + code_slot | string + '. Please enable it in order to make it active.'}}
data_template:
entity_id: >-
{{ 'input_boolean.enabled_frontdoor_' + code_slot | string }}
- alias: frontdoor Reset
condition:
- condition: state
state: "on"
entity_id: input_boolean.frontdoor_reset_lock
platform: state
to: "on"
- service: script.frontdoor_reset_lock
# - alias: frontdoor Clear Code
# trigger:
# platform: state
# to: "off"
# condition:
# state: "on"
# action:
# - choose:
# - conditions: >
# {{ True }}
# sequence:
# - service: ozw.clear_usercode
# data_template:
# code_slot: >-
# {{ code_slot }}
# - conditions: >
# sequence:
# data_template:
# node_id: >-
# code_slot: >-
# {{ code_slot }}
# usercode: >-
# {{ range(1000, 9999) | random | int }}
# - service: lock.clear_usercode
# data_template:
# node_id: >-
# code_slot: >-
# {{ code_slot }}
- alias: frontdoor Decrement Access Count
platform: state
condition:
- condition: state
state: "on"
# Check for Keypad Unlock code
value_template: >-
{{ (a[0] | int == 19) or (a[0] | int == 6) }}
{% else %}
{{ false }}
{% endif %}
- service: input_number.decrement
data_template:
entity_id: >-
{{ 'input_number.accesscount_frontdoor_' + a[2] }}
