Kia/Uvo stopped working
Hello
I have been using the Kia/Uvo integration for 2 months with no problem until a few days ago it stopped working and started saying unavailable.
I removed the integration and when trying to re-install it I cannot configure it.
Here what happens:
The integration installation looks fine.
When I input username, password and PIN (I also set Europe and Kia as options) I get an “Unexpected error” message.
Username, pw and PIN are the same I use in the Android app and they do work.
The log content is as follows:
2023-04-05 07:27:22.190 ERROR (MainThread) [custom_components.kia_uvo.config_flow] Unexpected exception
  File "/usr/local/lib/python3.10/site-packages/hyundai_kia_connect_api/KiaUvoApiEU.py", line 203, in login
    authorization_code = self._get_authorization_code_with_redirect_url(
  File "/usr/local/lib/python3.10/site-packages/hyundai_kia_connect_api/KiaUvoApiEU.py", line 1146, in _get_authorization_code_with_redirect_url
    parsed_url = urlparse(response["redirectUrl"])
KeyError: 'redirectUrl'
  File "/config/custom_components/kia_uvo/config_flow.py", line 159, in async_step_user
    await validate_input(self.hass, user_input)
  File "/config/custom_components/kia_uvo/config_flow.py", line 63, in validate_input
    token: Token = await hass.async_add_executor_job(
  File "/usr/local/lib/python3.10/concurrent/futures/thread.py", line 58, in run
  File "/usr/local/lib/python3.10/site-packages/hyundai_kia_connect_api/KiaUvoApiEU.py", line 208, in login
    authorization_code = self._get_authorization_code_with_form(
  File "/usr/local/lib/python3.10/site-packages/hyundai_kia_connect_api/KiaUvoApiEU.py", line 1239, in _get_authorization_code_with_form
    intUserId = "".join(parse_qs(parsed_url.query)["int_user_id"])
KeyError: 'int_user_id'
It seems like Kia changed something:
Same issue here, I get Config not ready: int_user_id
same here - int_user_id
And also same here, I thought my external IP became blacklisted as it happened the day after I lowered the refresh interval to the lowest possible.
Glad you guys are experiencing the same.
Also to bad it isn’t realtime info maybe HA Developers shoulda work together with Kia Connect developers to achieve realtime info.
Same here… Does someone already has a solution?
Hi all
Just updated from hacs, recreated the integration and all is working
Which integration are you using? I have a Ceed PHEV
It is called Kia Uvo/ Hyundai bluelink
