I’ve jailbroken my old Kindle 4 non touch so that it shows a lovelace panel. The panel is rendered on a server every minute and the kindle polls it every minute and displays it.
The device is always powered, but I also set the update frequency to 15 minutes in the past and the battery lasts quite some weeks. Using a CDN and using a different schedule each night extended it to almost one month.
Also, the Kindle 4 NT is quite hard to set up as it has no rtcwake and it’s not straight forward to start scripts after booting. The whole thing might be easier to build with newer Paperwhite models…
Thanks for sharing your project! Looks really nice
I’m trying to replicate it but I get this log output when running the container in portainer:
> [email protected] start /app
> node index.js
Starting browser...
Adding authentication entry to browser's local storage...
Starting rendering cronjob...
Server is running at 5000
Rendering http://192.168.178.50:8123/lovelace/casa?kiosk to image...
Failed to render TimeoutError: Navigation timeout of 10000 ms exceeded
at /app/node_modules/puppeteer/lib/cjs/puppeteer/common/LifecycleWatcher.js:106:111
Converting rendered screenshot of http://192.168.178.50:8123/lovelace/casa?kiosk to grayscale png...
(node:17) UnhandledPromiseRejectionWarning: Error: Command failed: convert: unable to open image '/output/screen.png.temp': No such file or directory @ error/blob.c/OpenBlob/3496.
convert: no decode delegate for this image format `TEMP' @ error/constitute.c/ReadImage/562.
convert: no images defined `/output/screen.png' @ error/convert.c/ConvertImageCommand/3273.
at ChildProcess.onExit (/app/node_modules/gm/lib/command.js:301:17)
at ChildProcess.emit (events.js:314:20)
at maybeClose (internal/child_process.js:1022:16)
at Socket.<anonymous> (internal/child_process.js:444:11)
at Socket.emit (events.js:314:20)
at Pipe.<anonymous> (net.js:675:12)
(node:17) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
(node:17) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
Thanks for your reply, I actually managed to make it work exactly as you suggest.
I’m not running Homeassistant in a docker environment but instead the easy install method using Hass OS. So in order to install your rendering software I have used the portainer add-on in homeassistant and successfully made it run - I see the png file gets created in the container. Now the issue is accessing it. I know I need to create a Volume in order to access the data inside the container. But at which URL is it than available? Can you post as an example which URL you use in your kindle?
The docker container exposes a single HTTP port. Any GET request to it will return the image.
So if your HA has the IP “192.168.0.100” and you’ve mapped the container’s port to 5000 (which is the default port) via portainer, then it’s available at http://192.168.0.100:5000
Thanks, I ended up understanding what to do and it runs now. Since I can’t use docker compose in my setup, all those steps have to be done “by hand”.
Since my Wlan is automatically off for some hours every night I realized the Kindle actually doesn’t manage to reconnect once the Wlan is available again. After searching a bit, I tried the following solution and it seems to work:
The code was supposed to call this reconnect command after failing to get wifi for 5 times (which means a delay of 5+4+3+2+1 = 15 seconds): see the code.
However there was a small bug in the utils.sh which was recently fixed by this PR. It caused the script to never go into this if condition and call the reconnect command.
So anyone who has the same problems: the code in the GitHub repo should be in a better state by now
Every now and then the tool stops working with this output:
Rendering http://192.168.178.50:8123/lovelace-kindle/0?kiosk to image...
Converting rendered screenshot of http://192.168.178.50:8123/lovelace-kindle/0?kiosk to grayscale png...
Finished http://192.168.178.50:8123/lovelace-kindle/0?kiosk
> node index.js
Starting browser...
(node:18) UnhandledPromiseRejectionWarning: Error: net::ERR_CONNECTION_REFUSED at http://192.168.178.50:8123
at navigate (/app/node_modules/puppeteer/lib/cjs/puppeteer/common/FrameManager.js:115:23)
at processTicksAndRejections (internal/process/task_queues.js:97:5)
at async FrameManager.navigateFrame (/app/node_modules/puppeteer/lib/cjs/puppeteer/common/FrameManager.js:90:21)
at async Frame.goto (/app/node_modules/puppeteer/lib/cjs/puppeteer/common/FrameManager.js:417:16)
at async Page.goto (/app/node_modules/puppeteer/lib/cjs/puppeteer/common/Page.js:784:16)
at async /app/index.js:31:3
(node:18) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
(node:18) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
Once again, can you give a me hint what could be going wrong?
This indicates that the machine (or Docker container) cannot reach 192.168.178.50. Hard to tell what’s the exact problem without knowing your (network) setup.
@sibbl I got this same error as above mentioned and the fix with RENDERING_TIMEOUT=30000 works, maybe add this to a new FAQ section on your github page.
