I managed to flash the latest Tasmota firmware on the touch dimmer (https://blakadder.github.io/templates/kingart_dimmer.html) and it also works perfectly with Home Assistant. However, is there a way to deactivate or lower the brightness of the LED lights on the face plate?
i donβt think you can dim lights but there is option to disable WIFI indicator light from ewelink app
find yourself how to turn wifi / button lights off from tasmota
Thanks @tech_fr3ak! Is it possible to deactivate the Wifi indicator light through Tasmota, as I have already flashed the Tasmota firmware to the dimmer?
Hi there, just a quick question on this particular switch.
Is someone able to help me with what is on what GPIO?
ie On/Off GPIO?, Increase brightness GPIO??? etc
