I like to use the additional Lovelace dashboard feature to create different dashboard for kiosk based devices in my house. The custom header HACS plugin does only work for the default dashboard.
All tips are welcome.
Thanks,
Rien
Thanks,
Rien
Are you receiving errors?
If your configuration is set up correctly, the resources will load for all dashboards in your config. As far as I know the custom header will need to be declared in every dashboard.
No errors
The default dashboard menu option is not visible on the extra Lofelace dashboards and settings done in the default dashboard have only effect on the default dashboard.
Like I said, custom header doesn’t seem to be set globally. You will need to set up custom header in every dashboard you want it to be enabled.
Ever find away to make it work
Thanks it is working now:-)
