Kiosk Mode for Raspberry Pi with Touch Display
even using the IP, you need to put http(s):// otherwise it is much more likely to error out.
Running into dependency issues on a fresh install of Raspberry Pi OS (32-bit), when using the install script:
Unpacking touchkio:arm64 (1.1.0) over (1.1.0) ...
dpkg: dependency problems prevent configuration of touchkio:arm64:
 touchkio:arm64 depends on libgtk-3-0.
 touchkio:arm64 depends on libnotify4.
 touchkio:arm64 depends on libnss3.
 touchkio:arm64 depends on libxtst6.
 touchkio:arm64 depends on libatspi2.0-0.
 touchkio:arm64 depends on libdrm2.
 touchkio:arm64 depends on libgbm1.
 touchkio:arm64 depends on libxcb-dri3-0.
dpkg: error processing package touchkio:arm64 (--install):
 dependency problems - leaving unconfigured
Processing triggers for gnome-menus (3.36.0-1.1) ...
Processing triggers for mailcap (3.70+nmu1) ...
Processing triggers for desktop-file-utils (0.26-1) ...
Errors were encountered while processing:
 touchkio:arm64
Installation of .deb file failed.
From the readme
This guide assumes that you are using a Raspberry Pi with the latest version of Raspberry Pi OS (64-bit) , along with a desktop environment (preferred using labwc).
So do a retry with a fresh 64 bit version of the OS
Didn’t think 32 vs. 64 would create dependency issues, but will retry with 64bit. Thanks.
Edit: 64bit worked just fine!
Is there a way to modify the existing code to expose a PIR sensor to the MQTT client running in your script? Then ultimately have it discovered by HA?
I am currently using the kiosk mode by using the tutorial by Mark Watt Tech, on a Pi400 with HDMI and USB Cable on a UPerfect Vertical Monitor
As this is Chromium in kiosk mode, when trying to view 1080p camera feeds they do not seem to work and I have been unsuccessful in enabling hardware acceleration.
Will this application improve video rendering?
As mentioned above it would be easier to use a sensor that is already directly integrated in Home Assistant.
But, If your goal is to learn how to add a custom sensor via MQTT you can use the TouchKio code base. It will take some time and programming experience but I outlined the basic steps under Development > Extensions in the README file:
The Electron application is also based on Chromium and doesn’t have dedicated improvements for hardware acceleration on Raspberry Pi’s.
I tried loading a 1080p video using touchkio --web-url=https://youtube.com on a DSI display and it just works fine and lag free, but I’m using a RPi 5.
No problems, I will try load it up on a fresh SD Card and see how it works. The Pi400 should play 1080p video fine. It is feeds from my arlo cameras.
Maybe consider running a separate test using the official Raspberry Pi OS image, as it could perform better that custom minimal installs, since some GUI improvement may be added there.
I will try that.
Where do I enter the data for MQTT afterwards? I actually entered it properly in the Arguments.json, but then Touchkio doesn’t start anymore. Reboot etc. of course everything done, sure. I successfully tested the connection from the Raspberry Pi to my Home Assistant server with mosquitto_sub, connection is fine. Thanks in advance!
As mentioned in the README you can re-run the setup any time by using touchkio --setup. This will guide you through the setup procedure, where you can also change the MQTT settings. Alternatively (or for testing) you can also start it directly. e.g.:
touchkio --web-url=http://192.168.1.42:8123 --mqtt-url=mqtt://192.168.1.42:1883 --mqtt-user=kiosk --mqtt-password=password
Yes, but there will probably be a configuration file where the access data will be entered, or not? But I will try it, thanks.
Is there any option to go back to desktop?
Yes, use the side panel to minimize the window as explained here:
This is awesome!
After struggling for some time with chrome in Kiosk mode doing weird stuff I got directed here by a Copilot query of all things.
I have the display turning on and off along with the office light which is fantastic.
All works super well on a Pi 4.
Cheers.
I got your app to work the first time and it looks really good (touch display Hannspree HT225+Rpi 4b with 4GB) including MQTT integration.
Let me ask a few questions though:
1. The monitor should display a screensaver after n seconds if you don’t touch it. Is there such a thing implemented?
It’s already mentioned in your readme - never mind.
  1. If you turn off and then turn on the “display” control element that is running in fullscreen via MQTT (HA), the app is in a frame and no longer fullscreen. How can you change that?
  2. The Rpi4 has a processor usage of 73%. The interface feels laggy. For example, I use a powerflow card and the flow dots, which normally move smoothly, jump back and forth. Is the Rpi4b too weak to display animated web widgets? Does anyone have similar experiences?
Thanks in advance.
Hm, this should not happen. Does the “Kiosk” mode select box in HA also change to “Maximized”? Maybe your screen behaves like “physically disconnected” when turned off and windows are therefore rearranged? Are you using the latest Raspberry Pi OS, what happens if you switch between Wayland and X11?
RPi 4 with 4GB should work fine, but extensive animations might be too much as the browser comes without hardware (GPU) acceleration. Also have a look into Performance struggles with rpi 4b · Issue #19 · leukipp/touchkio · GitHub, try another SD Card and report there if you find anything interesting.
did you add any featues about sleep-mode for hdmi displays?
I have a 22" beetronics display attached and would be happy if it goes to sleep after xx minutes without touch.
And the ability to wake the display again with touch?
Thanks!
