Is kiosk mode not supported anymore ?
It works on my tablet but i can’t hide the topbar
kiosk_mode:
hide_header: true
doesn’t work ???
kiosk_mode:
hide_header: true
doesn’t work ???
By now there shouldn’t be any problems if you have the latest kiosk update installed.
I installed through HACS so i guess i have the latest version.
Everything works fine except the thing i mentioned above.
Delete header true
Nope, didn’t work…
Which HA version do you have? Which kiosk version are you using? I’m aware that there have been problems since the first HA update this month, but these should now be fixed. If the latest updates don’t help you should try a backup and reset your system and then update again. Due to the changeover from the HA database, it may take a little longer for the system to start up completely.
HA Version 2023.4.2
Kioskversion 1.50.1
Thank you very much i will try that however… the last time i tried to restore a backup, nothing happened.
There are now HA 2023.4.4 and Kiosk 1.8.3
Hi, have a look at GitHub - thomasloven/hass-browser_mod: 🔹 A Home Assistant integration to turn your browser into a controllable entity and media player
I don’t see any HA update to install.
Are you sure we are talking about the same integration here ?
Wich one to choose ? I can’t see another version ?
Thank you so much for your time.
Hi, thanks Nick ! I will take a look if a can’t get fully working.
So just for info the kiosk mode has nothing to do with the fully kiosk browser. Kiosk Mode is a HACS integration.
Yesssss…got it working now.
I was confused between kiosk-mode and fully browser mode.
Thank you so much.
I really appreciate this !!!
No problem for that one is there that one helps others.
I had the same problem. There’s a new completely separate version of Kiosk Mode in HACS, under “Frontend”. Installing this version fixed the issue for me.
