jruben4
(Jason)
June 6, 2024, 10:04pm
1
Trying to set up one of my dashboards to be in kiosk mode. In the yaml config for that dashboard I added the kiosk mode setting like below - but it’s not removing the side bar or header. What am I missing?
title: Outdoor Weather
path: outdoor-weather
icon: mdi:weather-cloudy
kiosk_mode:
hide_header: true
koying
(Chris B)
June 7, 2024, 9:44am
2
Did you actually install the kiosk-mode custom component from HACS?
jruben4
(Jason)
June 7, 2024, 12:55pm
3
Yes, and restarted HA, presumably it’s installed correctly.
koying
(Chris B)
June 7, 2024, 1:00pm
4
You seem to be at view level, not dashboard, is it not?
jruben4
(Jason)
June 7, 2024, 10:11pm
5
I tried to put it at the root of the dashboard config, as well as in the view config, neither seems to work:
kiosk_mode:
hide_header: true
- title: Home
kiosk_mode:
hide_header: true
cards:
jruben4
(Jason)
June 7, 2024, 10:24pm
6
Figured it out - had to add as a resource under ui-lovelace.yaml even though I installed it with HACs…
koying
(Chris B)
June 8, 2024, 8:35am
7
AFAIK, as soon as you have a resource:
tag in your configuration.yaml, you always have to put the resources manually, be it coming from HACS or not.
