Digging up an old thread here…
I have just started to use HA and I have added my KIRA modules to the configuration.yaml.
When restarting HA I get an error.
Logger: homeassistant.setup
Source: components/kira/init.py:119
First occurred: 11:34:00 (1 occurrences)
Last logged: 11:34:00
Error during setup of component kira
File “/usr/src/homeassistant/homeassistant/setup.py”, line 253, in _async_setup_component
result = await task
File “/usr/local/lib/python3.10/concurrent/futures/thread.py”, line 58, in run
File “/usr/src/homeassistant/homeassistant/components/kira/init.py”, line 134, in setup
load_module(CONF_SENSOR, idx, module_conf)
File “/usr/src/homeassistant/homeassistant/components/kira/init.py”, line 119, in load_module
module = pykira.KiraReceiver(host, port)
File “/usr/local/lib/python3.10/site-packages/pykira/receiver.py”, line 34, in init
self._socket.bind((host, port))
OSError: [Errno 99] Address not available
Not understanding why this is happening as all the KIRA modules are connected.
the config yaml is,
