Kismet wifi monitor device_tracker component
I have created a new custom device_tracker component that connects to a kismet server instance and tracks people (MACs actually). Kismet (for those who do not know it) is a wifi monitor program that puts a wifi card in monitor mode and hops around the channels listening for wifi beacons and probe requests. It can capture packets, create reports and recently has a REST API that you can query to see if MAC address AA:BB:CC:DD:EE:FF was seen around in the last 50 seconds. This is what this tracker component does.
To use it, you need a recent kismet version. Versions bundled with Ubuntu 16.04 or 18.04 are too old and don’t have the REST API. You can install it by following this guide: https://github.com/kismetwireless/kismet/blob/master/README. You’ll also need a wifi card that supports monitor mode. You can use multiple servers located at different places if needed.
Currently, the kismet device_tracker can be used as a custom component - which you can install following these steps:
 $ sudo su - homeassistant
 $ cd .homeassistant
 $ mkdir -p custom_components/device_tracker
 $ cd custom_components/device_tracker
 $ wget -O kismet.py https://raw.githubusercontent.com/mad-ady/home-assistant-customizations/master/custom_components/device_tracker/kismet.py
You will need to edit configuration.yaml and add the component:
 device_tracker:
   - platform: kismet
     interval_seconds: 30
     host: 192.168.1.15
      port: 2501
      consider_home: 420
     clients:
       - 84:98:66:47:cf:aa
       - d0:31:69:38:f2:99
     ssids:
       - DIGI
For extra debugging, you can set the component to debug inside the logger as well:
 logger:
   default: error
   logs:
     custom_components.device_tracker.kismet: debug
Once you restart the component will connect periodically to the kismet instance and query for the devices you listed. It will get results for the last ā€œinterval_secondsā€ period (e.g. for the last 30 seconds), so even if the mobile device was active for a little while in that interval it will get picked up and reported. The length of interval_seconds only affects how quickly a device is seen, not whether it is seen or not.
The parameters have the following meaning:
  • interval_seconds - how often to ask for updates from the kismet server
  • host - the kismet server IP/FQDN (127.0.0.1 by default)
  • port - the port where kismet is running (2501 by default)
  • consider_home - how long should a client be still considered at home if he hasn’t been seen (7 minutes is ok for clients with wifi open, but not associated to a network. May depend from device to device)
  • clients - a list of MAC addresses to look for. Can be a regular expression
  • ssids - a list of SSIDs to look for. Can be a regular expression
Devices which are discovered are added to known_devices.yaml, like regular trackers.
Now, I need the community’s help to add this as a standard component inside HA. I can add the code and ask for a PR, but what repo do I need to fork for the documentation? Also, is the code written ok to be used by others? Do I need to change formatting/add more comments?
Ohhhh…very cool. Thank you very kindly. Look forward to finding the time to playing with this. :slight_smile:
@mad_ady this worked pretty well for me up until some months ago…
Have you used it or found something similar?
Hey! I’m actually in the process of reworking it a bit. I want to test it with current kismet versions and there is a configuration issue that causes HA to complain on startup. I’m doing some internal testing and cleanup and hope to push it to HACS in a few weeks. I too am interested in getting it up to date :slight_smile:
Will keep you posted.
If you want any help I have had kismet running recently and have a few sensors I can test it on.
When I used this I wanted to keep track of all local devices, i.e. not just mine, as a sort of Intrusion Detection System/log, etc. It sort of polluted the device tracker entity list though!
My current system is in nodejs and uses node red for a UI, and tracks AP’s as well as clients locally, and when I travel (err, wardrive/walk) around. Mapping/graphing/statistics… want to use it to keep track of my own devices also. Hope to have it posted shortly.
Interesting setup :slight_smile:
My current plan is to rewrite the device_tracker for kismet so that it doesn’t register anymore as a legacy device tracker and so that it uses current kismet API. The API I was using (from summer 2018) no longer works with newer kismet releases (kismet introduced mandatory login from spring 2019 onwards). So, it will be a bit of a rewrite, but I want to do it anyway. Not sure how much time I have, but I’m working on it in my spare time.
One thing I want to add is GPS support to the device tracker, so that it reports kismet’s location to Home Assistant - so that if you have a tracked entity that moves around you will get the zone the device is in HA. If you have GPS-enabled kismet I may need your help to test some queries.
Hey, I will go and take a closer look at your code and get kismet up and running in the next few days. I have phones running BlueNMEA that I use for GPS. I don’t have zones setup yet though.
I want to integrate my code into HA in some way, it is similar in ways to your plugin - but doesn’t use kismet.
Mainly because I’ve had it running for days on end and it crashed and broke interfaces more often than not, but also because code I’ve been running for a few years just works at recording wireless macs into mongodb.
How do I get notifications of responses to threads?
Ahh I have to mark the post as Watching instead of Tracking.
Hey @ceebee,
I pushed my changes to github: https://github.com/mad-ady/home-assistant-customizations/commit/07d3f02387a3ea31c0819f408e927f63d50514d7
It should work with the current HA version and kismet 2019-09-R1.
I still need to rewrite it to add support for GPS coordinates. But this should do in the meantime.
@ceebee Is your code available somewhere, I’d be interested in your Node-Red version you have running?
Hey, I’m still working on it, I will try and post something soon!
I am also interested in this. Have you gotten it running?
Any plans to add the Kismet Bluetooth tracking?
Sorry guys, I haven’t been active on this - mostly because I stopped using Kismet wifi tracking, and also because the device_tracker API changed since I’ve implemented it and it needs to be completely rewritten to use the newer API.
Once there is a stable device_tracker (with regard to API), I guess BT tracking can be added, as long as it’s exposed by Kismet.
So, apart from my original post, I don’t expect to be working on it any time soon. Fell free to fork it and improve it for your needs, but it requires rewriting mostly…
It’s sad that the project was abandoned … it worked well, it detected my device further and earlier than it was connected to the wifi.
I made a kismet addon for hassio . If someone continues the project and corrects it for a modern device_tracker api, I will be happy to share addon.
Does this work for Bluetooth devices? I want to integrate 2 itags (cheap bluetooth keyfinders) in home assistant.
Any chance of this getting fixed up or updated? I recently got kismet up and running in my home but would like it to connect to my home assistant. Looks like some code may need to be re-written. Maybe can use some code from here? GitHub - josevnz/kismet_home: Kismet home contains a group of scripts to help you secure your wireless home network
Have you looked at Nmap? Theyre not exactly the same but, they have a lot of overlapping festures and functions.
Sorry guys, as I said earlier somebody needs to rewrite the module according to the new HA API. D
Hi all,
I’ve managed to get the Kismet added as a sensor to HA to get what I want without the python code. Just modified the device alert settings on the Kismet from kismet_alerts.conf, here can specify MAC or OUI of devices with ā€œdevicefoundā€ alert. Then added the following to configuration.yaml in HA.
  • platform: rest
    json_attributes:
    • kismet.alert.header
    • kismet.alert.source_mac
      method: GET
      resource_template: ā€œhttp://[kismet_address]:[port]/alerts/all_alerts.jsonā€
      username: [censored]
      password: [censored]
      authentication: basic
      scan_interval: 60
      value_template: ā€˜{{ value_json[0][ā€œkismet.alert.headerā€],value_json[0][ā€œkismet.alert.source_macā€] }}’
Now I can create HA automations to my liking using the sensor and json attribute changes. Thanks all for your guidance along this journey!
