Hi, I need to help with my project. I doing a kitchen center. I have 15,4 inch screen with IR touch frame and an HDMI control board. On the screen I want the clock, date, it is in the first block. In second block will be internet (video, youtube…). In another block are recipes (doc, docx, pdf, epub, txt and etc.). In another block is stopwatch with signal. In the last block is calculator. It should be similar to this (does not):
[home center](https://static.makeuseof.com/wp-content … hboard.png)
If this center we will not to be using then will be a slideshow (images).
My kitchen centre
TIME – time, date, name day
REMINDER – meeting, visit doctor, birthday, comment, etc.
RECIPES – read files as: doc, docx, pdf, djvu, txt, epub, etc.
WEB – internet, email, recipes, youtube, videos, etc. - maybe browser
SHOPPING BASKET – save, read and delete items as: milk, eggs, etc.
STOPWATCH – have two or more stopwathes, start differently…
CALC – calculator, weight conversion, etc.
OTHER - other
How does this relate to Home Assistant?
It sounds like you want a web server with tome other custom software. I see no reference to home monitoring or automation.
I have RPi3 so I put it here. I thought it is OK because assistant is for help, easy, simply… Does anyone have any idea? How could I do it? I need dashboard with my widgets. Thx.
I think the question is - Do you plan on running the Home Assistant software as shown at www.home-assistant.io, or are you asking here because you want to build a “home assistant” (note the careful choice of lower case and quotes in the second version)
sore of like how Google Hub for the SmartHome is not a SmartHome hub by the normal definition. In fact it may do what you want in the kitchen.
Sorry but I don`t know. I need design as home-assistant (dashboard) on my RPi3(screen). If it is possible to how do it?
There are likely other products designed to do what you wish but Home Assistant was not designed for this. It might be able to be made to work but in the long run it would be easier to design something yourself. At least, that is my opinion of the situation.
No one knows how to make it simplest?
It’s not that people don’t know; it’s more that you have grossly misunderstood the product people are here to support. It does not do, without massive customization, what you are asking it to do…
This site is to assist with the product HOME ASSISTANT; not assist you with a free custom freelance product of your dreams.
