Know of Any Solar Hybrid Inverters with built in Ethernet for HA in the U.S.?
Is anyone aware of any U.S. compatible (240v split phase) solar hybrid inverters with built in ethernet that work with Home Assistant and can be purchased in the U.S.?
Hello Profile - DataMeister - Home Assistant Community,
I plug that into Google and get a huge list of stuff. Compare that list to what integrations HA supports and which are available thru GitHub using HACS.
NOTE:
This is an observation, I don’t have one of these. Just trying to help you with your question to get a better response.
Then when you find something(s) that might work for you ask if anyone has one of these. You will get a much more focused response than the method you are attempting. (Too many variables open and no effort shown on your end).
i Think Sungrow…
