I am getting really happy with my hassbian setup. So its time to get device tracker working properly for automations and I am running into issues.
Owntracks and CloudMqtt is all working fine. I can see updates on Websockets UI.
My issues seem to be with Home Assistant, and I feel like I am missing something simple. I am currently getting the below error:
2017-07-14 20:29:49 ERROR (MainThread) [homeassistant.components.device_tracker] Unable to load /home/homeassistant/.homeassistant/known_devices.yaml: Config file not found: /home/homeassistant/.homeassistant/known_devices.yaml
I have had this working once, about a month ago. The known_devices.yaml created itself as per the below in the documentation:
Once device_tracker is enabled, a file will be created in your config dir named known_devices.yaml. Edit this file to adjust which devices to be tracked.
(Device tracker - Home Assistant)
For some reason the above doesn’t seem to be happening. When I put a copy of known_devices.yaml I have from a backup, the error disappears. However none of the information repopulates and I can’t track anything.
I have spent a few hours trying to get this to work now. Following the BRUH video etc. I have removed mqtt and device_tracker from the yaml, restarted home assistant, popped everything back in but I don’t seem to be getting any closer.
PS: I know there is a bucket load of posts related to this and I have ready many many many posts and tried everything I can think of. Hence why reaching out!
in my case the solution with automatically created known_device.yaml file was to check and update the authority for the file.
I’m working on a Linux system and I changed the owner, the group and the ACL-settings (getfacl, setfacl).
Then it works fine
I have the same problem - no known_device.yaml file being created. I’m running HA in a Docker container on Lubuntu 16.10. Could you please tell me what changes you made - i.e. did you change details of the known_devices.yaml file, or the config folder? What did you set owner/group to?
I’ve manually created a known_device.yaml file using the touch command, and the ACL settings look like this:
I guess my group authority isn’t a problem as I just created another device_tracker as an experiment - using the ASUSWRT platform. After adding that device_tracker the known_devices.yaml file was created fine, and was populated with all of the devices connected to my Asus router. It’s just the owntracks device tracker that is not creating the known_devices.yaml file (and is not updating the file created by the ASUSWRT device tracker either.
