I recently set up a Kono Z-Wave thermostat. It’s set to run in Celsius, but for some reason the max and min temperature threshold is showing up in Fahrenheit.
Here are the way that the settings look in Z-Wave JS UI which looks correct and it appears correctly on the thermostat itself:
But in HA, the max and min temp are in showing up in F.
This is making things not work properly when I try to adjust the temperature in the HA UI, of course.
Any ideas on how I can sort this out?
