KNX 3rd Party API (Server - Gateway)
Hello guys,
I am a bit confused, if someone can help.
The KNX Association released this KNX 3rd Party API Server that can be hosted on a RaspBerry Pi using Docker. They have a tutorial for that on Youtube.
KNX IoT 3rd Party API server demo part 1 - Ubuntu Core - YouTube
On their documentation https://gitlab.knx.org/ (it is private - to login use the credentials shown on the video " GitLab documentation overview" in the tutorial) they claim " Any hardware running docker (including Raspberry Pi) With appropriate settings, can be connected to a KNX installation (only for versions >= 2.0.0.0, current)".
But this is not true, is it? To connect to a KNX installation you need a gateway that is able to connect (with some kind of hardware) to KNX devices that use TP and at the same time run a KNX 3rd party API server. A normal Raspberry Pi can run the server but cannot connect to the installation.
Please provide some information and some suggestion if you you any KNX 3rd Party API gateways.
Thanks a lot!
Without watching this video I can assure you it would definitely need a KNX IP interface or router in the TP installation - just as HA would need one to connect.
Afaik there are currently no hardware Knx IoT Gateways on the market.
I thought so. Thanks a lot for the reply Matthias!
